Old 01-22-2009, 12:53 PM
smjw1227 smjw1227 is offline
Oxygen Sensor
I have a 97 Ford taurus and my check engine light was on, took it to auto zone and they told me that my oxygen sensor was bad...how important is it to replace this? I know it can cause the car to run rough but will it cause the car to break down if it is not replaced immediatly? I'm leaving next week for a 500 mile drive and don't want to break down during the trip.
Old 01-22-2009, 01:57 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Oxygen Sensor
Did they give you the full code? Rarely will you receive a code that states the oxygen sensor is bad. The codes may indicate the oxygen sensor is reporting a concern, but it doesn't mean the sensor is bad.
You should get the full code (in the form P0123) and post it here for better detail.
-Rod
Old 01-22-2009, 02:01 PM
Re: Oxygen Sensor
Sorry the full code was P0430 The PCM has determined that the catalyst system efficiency for bank 2 is below threshold for the current engine operating condition
and there was a P0420
...the worker told me it was the oxygen sensors
Old 01-22-2009, 06:45 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Oxygen Sensor
You actually need a scan tool that will allow reading of the PIDs on the vehicle. Usually an O2 sensor will not cause a P0420 or a P0430. If a scan tool shows both front and rer sensors changing at the same rate, the converter is usually at fault. Try erasing the codes and see how long it takes to come back. I don't think it will cause any problems unless the converters are plugged. If they are plugged, you are likely to have problems.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-23-2009, 03:53 PM
Doug Tatham Doug Tatham is offline
Re: Oxygen Sensor
As Way2Old said, it is unlikely for both the 1st and 2nd bank sensors to go bad at the same time. I'd start looking at your catalytic converter, especially if you have over 150K on your car. Another thing to look at is leaks in the exhaust. This may help: http://www.ehow.com/how_4506286_insp...rd-taurus.html
