Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-17-2009, 04:52 PM
crobar1 crobar1 is offline
96 caprice 4 door window problems
I ahve 2 windows that the motor will lower and raise but the glass does not track. I can close only by guiding by hand and working the switch. A machanic says a little gismo is broken and you have to replace the entire guts.
I'm going to tear into it to find and rebuild, does anyone have a heads-up on what I'm looking at?
Old 01-17-2009, 07:23 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 caprice 4 door window problems
I am moving this to the Caprice forum, this is not a classic.
Old 01-17-2009, 08:10 PM
j cAT j cAT is offline
you will most likely find a plastic part cracked..this is usually from vandalism/breakin or operating the windows when frozen..
It may be possible to glue these broken pieces or best go to the scrap yard....
Old 01-17-2009, 09:04 PM
Blue Bowtie's Avatar
Registered Offender
There is usually no need to replace "the entire guts" as you have been advised. The lower channel guides are plastic, and break under stress. There is a factory upgrade roller which replaces the "hot dog" shaped slider guide and does not break.
Window Guide Roller - GM Part No. 9666748
The lower regulator arms will have to be exposed, and the old sliders removed. The replacement is relatively straightforward once the mechanism is exposed.
Old 01-18-2009, 09:12 AM
96capricemgr 96capricemgr is offline
I don't have the PN but many parts stores stock the rollers in the HELP brand.
Also seems to only be the rear one on each window that breaks.
96 Caprice Medium Garnet Red
11.56 at 115.9mph naturally aspirated
94 Caprice wagon, rotted out POS
Old 01-18-2009, 11:47 AM
I assume the GM part can be obtained from a Chev. dealer?
Old 01-18-2009, 03:37 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Or a Buick dealer in some cases as the Roadmaster shares the same issue and parts. Not all Chevy or Buick dealers may stock these as demand has decreased over the years, but they should still be able to get them fro a central warehouse or another dealer in the area.
Here is a link to a thread in the Roadmaster forum that details the issue with some helpful info:http://www.automotiveforums.com/vbul...d.php?t=562839
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 01-18-2009, 07:28 PM
I would remove the door panel and take a picture of the broken gizmo then we can guide you better on this repair...
Old 01-18-2009, 09:38 PM
That is the case in most situations, where a customer is "advised" to replace the entire regulator which can run well over $300 plus labor. A good money maker for the shop. The part number listed is for a revised design with a more rounded end to slide better in the tracks. I might also suggest you buy some clips that hold on the inner door panel as many of the old clips tend to break while removing the door panel to gain access to the regulator/door glass. The part number for these clips is 15600382 the last time I checked.
Also this is a known problem with these B body cars the Caprice, Roadmaster, and Impala SS. The OEM rollers were of poor design causing them to fail after a few years.
Old 01-20-2009, 09:33 AM
Go to this part store each kit is 28.oo.. http://www.impalasuperstore.com/nais...categories.asp
Old 06-06-2009, 03:46 PM
I have attached two types of photos; 1 of how I repaired the panel clips which were broken when removing and the plastic insert that I made out of the original found at the bottom of the door. The GM / Help part was not the correct part for this model. Thanks for the help and The front passenger door is back together and working fine. I still have the drivers side rear door window to fix when I have time.
Pictures will have to came later as I can't figure out how to resize and upload.
Old 06-06-2009, 05:46 PM
Here's link to a free program I downloaded to my computer and use with excellent results to re-size my pictures for sites like this: http://bluefive.pair.com/pixresizer.htm
Once you have re-sized the pic you can use one of the free photo hosting sites to upload and post the pics here. Good luck.
Old 06-06-2009, 06:51 PM
did the link help you understand this issue ??? of these window plastic supports. the rubber seal/guide must be dirty-sand and this is causing the windows to drag,,,,see if with the door panels removed you can wash these guides and when dry spray with silicone lube..
the rubber may also be hard and does not allow smooth window operation..
Old 06-06-2009, 07:32 PM
Thanks it works just fine.
Old 06-06-2009, 07:34 PM
The help has been great. I have quite a few vehicles on this place and do need help in keeping them up.
Thanks again
