Old 03-22-2003, 09:16 PM
91hondaguy 91hondaguy is offline
hook up vtec
ok i have a crx with mini me set up, now i need to hook up the vtec.
i want to do this cheapest way as possible
what will i need?
thanks
i own a 88 yellow CRX
www.northwestshowoff.com
Old 03-22-2003, 09:22 PM
91civicDXdude's Avatar
at minimum, the cheapest way you cn hook it up is with a direct toggle switch. this will cost you about $.05 but it sucks. The best cheap way is to get an MSD (or similar) rpm activated switch. they retail for 50.00 or so plus you have to buy the rpm modules.
One of the best ways would be to get a Field SFC-VTEC (or similar) VTEC controller. that way you can adjust the fuel settings as well.
Old 03-23-2003, 06:24 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
the vtec controllers require a vtec ecu.
Old 03-23-2003, 06:25 AM
no they dont. I have a PM6 CRX Si ECU and im using a Field SFC-VTEC. it works fine.
Old 03-23-2003, 07:59 AM
Oh, well how about that. Sorry. Now, I have a question for you then and I'm not being sarcastic or a smartass. Did you just wire up the vtec controller or does it piggyback off the ECU? I have a sohc vtec that I have yet to activate my vtec.
Old 03-23-2003, 08:19 AM
the VTEC controller interrupts the map sensor wire. Pretty much, all you do is hook it straight up. It will control vtec via standalone control. It controls the fuel by intercepting the MAP sensor wire to fool the ECU into thinking the map sensor says it needs more fuel.
You can find a chart telling you how to wire up the Field SFC-VTEC to a pm6 ecu @ http://www.geocities.com/bing_bong916/vtec_cont2.html
On a VTEC ECU, it has more wiring that is spliced between the harness and ECU, but on our PM6 ECU's there is only 8 wires to hook up.
power
ground
VSS (speed sensor) (x2)
map sensor (x2)
ignition output (for digital tach)
vtec selenoid
the grip of other wires coming out of the unit aren't use in this case.
LS/vtec ?? what do i need to hook it up? leobags '88 - '91 Civic | CRX | Wagon | Shuttlee 0 04-20-2006 02:23 AM
Hooking Up Vafc For Vtec.... jacer63 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 05-06-2005 01:31 PM
which should i hook vtec up 2? civicdemon91 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 03-15-2005 07:47 PM
vtec hook up???? darren1977 Let's get Technical! 1 02-23-2005 04:25 PM
helP guyZ! jusT SWAP NEED VTEC TO BE HookeD UP.. aZN_bABY '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 11-15-2003 11:48 AM
