'95 suburban a/c
I just bought a '95 suburban. First large Suv I've owned. The a/c compressor seems to be much louder than on any other vehicle. It is also much bigger. Is this common with these compressors, or is it going out? It does not get hot as though there is internal failure. Any info would be nice. thanks.
Re: '95 suburban a/c
Is this an A6 compressor or the R4?
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
low oil/refrigerant will cause the compressor to make more noise. |
Your R-4 compressor probably has internal aluminum yoke wear.. you can tell by checking the rotational lash - with engine off- see how much rotation you get by gently rocking the clutch on the compressor back and forth rotationally- If you have rear air option- (you probably do) then there was a TSB to reposition the rear TXV sensing bulb- to not allow liquid refrigerant to enter the compressor from the rear system- liquid creates early wear on the aluminum yokes inside the compressor and the subsequent lash and associated noise. I've seen a bunch of these...A new compressor will quiet it down, but without the TSB enacted, you will soon have the wear and noise return.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
