Old 12-29-2008, 06:58 AM
davem5761 davem5761 is offline
2001 Grand Prix-Key stuck in Ignition/Ignition won't turn
I used the Manual key release under the steering column to remove my ignition key because the ignition would sometimes stick and prevent me from turning it to the "off" position to remove the key. Now I can't start the car because the ignition doesn't turn past the first "on" position (the same position it would get stuck on when I would shut the car off)
Friend's Pontiac did the same thing, had it "fixed" a couple times, but never was fixed
Old 12-29-2008, 09:44 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2001 Grand Prix-Key stuck in Ignition/Ignition won't turn
Welcome to AF.
It sounds like the ignition switch key cylinder is bad.
When in PARK and foot on brake pedal and depressing the button on the top of the shifter do you hear the key release solenoid clunk in the steering column?
Timeslip 08/12/06
AF Community Guidelines
Old 01-05-2009, 02:00 PM
Chipnix Chipnix is offline
My friend had the same problem, if you tilt your steering wheel upwards, underneath is a small hole, if you can fit your finger in ther (or use a screwdriver) and screw around with the cylinder, it will release....well at least thats how she had to do it! lol
Old 01-08-2009, 11:11 AM
Sorry I took so long to reply, but you were right BNaylor, the cylinder was bad, thanks for the info
Old 01-08-2009, 12:24 PM
BNaylor's Avatar
Thanks for the feedback and glad we could help. Hopefully your post helps out others with a similar issue.
Timeslip 08/12/06
