Old 12-28-2008, 11:12 PM
04SilveradoLS 04SilveradoLS is offline
ABS Problem
Is it possible to have an A.B.S. problem without an A.B.S. light?
My rear brakes on my 04 C1500 are almost non existent, until I remove the fuse for the A.B.S.. Anyone heard of/had this problem? If so, is it the computer or valve body at fault?
Old 12-29-2008, 12:04 AM
Blue Bowtie's Avatar
Registered Offender
Re: ABS Problem
There may be a reprogram available for the ABS to correct that. The dealership should be able to identify if your's is among those affected.
Old 01-01-2009, 12:06 PM
j cAT j cAT is offline
Re: ABS Problem
can you explain when exactly this occurs ? and any other unusual symptoms...sounds etc..
It is possible its the front wheel sensors...
Old 01-01-2009, 04:50 PM
MILLERTIME651 MILLERTIME651 is offline
Re: ABS Problem
I know there a pending recall on the abs sensors. I have a 99 1500 that the abs wasn't working properly. I took it to the nearest dealer and they told me about them and they turned out to be corroded. I would call your dealer asap about this.
