Old 12-23-2008, 07:51 PM
dubhead89 dubhead89 is offline
Question Best Exterior Black
Hey, I'm new to the forums and pretty new to modeling; I was wondering what kind of black you all would recommend for the exterior. Would a Testor's gloss black work? Thanks.
Old 12-23-2008, 08:49 PM
taliesen's Avatar
taliesen taliesen is offline
Re: Best Exterior Black
You're likely to get a different answer from each person that replies - everyone has their favorite type.
Personally, I hate enamel paints - I only use them when there is absolutely no other choice for that color, for minor detail painting, or as a base for Alclad polished finishes - they take forever to dry for me. Acrylics tend to dry a bit softer, so to me they're not ideal for body painting. That being said, I've seen others achieve brilliant finishes with these paints - but I can't get the hang of it.
Personally, I mostly use Tamiya lacquers (you'll see a lot of TS-## references here - those are Tamiya). They dry pretty quickly, go on smooth out of the can, and seem to be pretty forgiving for the most part. I usually decant them to a spare glass bottle and then airbrush them, but that's more to save paint - the cans (like all cans) tend to spray a lot more paint than you need, and most of it ends up on the floor of the spray booth.
I've done a few with Zero paints, which are a base coat/clear coat system, and I'm going to use their black for the first time on my current Lambo build - but I'm nowhere near the paint stage on the body. The other colors have been great, though . . . .
Jonathan
Current projects:
1/12 Testors Lamborghini - http://www.automotiveforums.com/vbul...d.php?t=930745
Completed projects:
1/12 Porsche 934 Turbo RSR - http://www.automotiveforums.com/vbul...d.php?t=933988
No trees were harmed in the sending of this message; however, millions of electrons were terribly inconvenienced.
Old 12-23-2008, 08:50 PM
Hawk312 Hawk312 is offline
The two Corvettes in my sig were painted with Dupli-Color universal black. I haven`t found anything better. The color seems deeper and darker than both Tamiya and Testor`s. However, you must clear coat it and buff it out.
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 12-23-2008, 09:09 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Welcome to AF!
My personal favorite is CobraColors Ferrari Nero Tropicale. Bit of a shame about the availability, though. When I run out, I expect I'll switch to Zero, or airbrush decanted Tamiya lacquer.
PHOTOBUCKET SUCKS
Old 12-23-2008, 09:47 PM
Wow, those Vettes are gorgeous. I found this site yesterday and have just been looking at people's cars and been amazed at the detail...so many models are so complex!
I got the '79 Camaro Revell kit, I think I'm going to steer clear from the black for now cause in reading the FAQ, I'm not really sure I understand the "buffing out" of certain colors. I just went to the Hobby Lobby near by and bought some spray primer and a copper color.
Basically you spray your coats primer, let it stay for a week or so, spray your primary color, let it sit some more, clear coat, decal, and wax? Do only lacquers require buffing out with rubbing compound? Or enamels and acrylics too? Thanks a lot!
Old 12-23-2008, 10:03 PM
taliesen's Avatar
Letting the primer dry for a week is overkill, but if you're going to polish the paint you'll want to wait that long (unless you have a dehydrator setup).
I have gotten a lot better at the painting process since checking out the tutorials around the web - one very good site is http://www.italianhorses.net/ - the guy who runs this is also a regular here on AF (360spider - check out his F40 in the motorsports WIP).
Jonathan
Current projects:
Completed projects:
Old 12-24-2008, 05:28 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Although black is a gorgeous color when applied and treated correctly, it is one of the hardest colors to get down correctly. It shows every inperfection.
If you've never done a gloss black car before, expect to spend a lot more time perfecting.
The two hardest colors to get down well imo are black and white. If you really want to do black right away, I would suggest a 2 stage paint process. IE: Zero base + a clear. That should make things a bit easier.
HTH,
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 12-24-2008, 08:46 AM
mn80228's Avatar
mn80228 mn80228 is offline
If you are new to the hobby, I would recommend that you try the Testor's black.
There are a couple of reasons....
You don't need an airbrush like you would with the Zero paints.
Testors (at least around me) is usually a little cheaper than Tamiya paints.
And if the primer is nice and flat (sand out with 600 or 800) grit, the testor's will lay down nice and smooth. And if you are using gloss black, you may just get a nice enough shine without having to polish.
Of course if you are adding stripes or decals, you will likely want to clear over that.... but for a basic, no fuss quick black paint, testor's is a pretty safe bet.
Old 12-24-2008, 11:37 AM
JimboCO JimboCO is offline
Mr Color super gloss black works really well.
Old 12-27-2008, 03:33 AM
matador88's Avatar
matador88 matador88 is offline
gunze C black (C2) is the best one around. for me the normal one is better than super black
