Go Back   Automotive Forums Car Chat > Buick > Century
Old 12-20-2008, 09:50 AM
mac79 mac79 is offline
Angry 1994 buick
1994 buick century runs sluggish and dies. have changed plugs ,wires,icm,cam sensor,crankshaft sensor, and maf sensor. still has same problem. SOMEBODY PLEASE HELP! 3.1 ENGINE
Old 12-20-2008, 10:16 AM
1994 Buick
Does Anyone Know Where The Ecm Is Located On 94' Buick Century With 3.1
Old 12-20-2008, 10:52 AM
tempfixit tempfixit is offline
Re: 1994 buick
Have you checked the fuel pressure with a fuel pressure gauge?
Also check the Throttle Position Sensor.
Old 12-20-2008, 11:18 AM
Re: 1994 Buick
Check this site, it has a service manual with the comptenant locations plus other info that can help.
http://www.autozone.com/N,4294962921...locsSelect.htm
hope this helps
Old 12-20-2008, 12:37 PM
Re: 1994 buick
can the tps be tested? thanks
Old 12-20-2008, 01:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1994 Buick
Your other post has been merged with the new one concerning ECM location to maintain continuity.
Timeslip 08/12/06
AF Community Guidelines
Old 12-20-2008, 03:13 PM
Re: 1994 buick
Yes TPS can be tested. Using a voltmeter, you shuld have .5 volts @ closed throttle, voltage should rise a throttle is opemed, should have 5 volts @ Wide open throttle.
Send me a PM, I will email you a link that has more info that will help you.
