Old 12-16-2008, 02:00 AM
indolene's Avatar
indolene indolene is offline
Tamiya Super 7 kitbash
First post and first kit build in three years. Thought I'd share since you've all shared so much with me.
This kit was never going to be built OOB. Inspired by other AF Super 7 builds and various special edition Caterhams. Only question was how far to take it, limited to physical kit limitations ie: 5.0l Mustang V8 or wide 20' racing wheels too big without major modifications although some mods such as narrowing the racing seats and tunnel needed to be done. At the end of the build, the only unmodified original parts used will be the front upper and lower suspension arms, kingpins, and rear axle tracking links. Only things I haven't figured out are how the steering rod is going to fit (realistically) around the V-8 and the color.
notable kitbash parts and source:
hood louvers - 1/12 tamiya Honda NSR
engine block/headers - 1/24 Ertl V8 Lola-Chev indycar
wheels - 1/24 Revell Mini
dash and steering wheel - 1/20 tamiya Mclaren MP4/5b
Enough words, I hope you enjoy
Old 12-16-2008, 05:53 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Tamiya Super 7 kitbash
Interesting build. Looking forward to what you can do with it...
Although may I ask that you edit your last post by pressing enter after each photo?
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 12-16-2008, 11:28 AM
AustinMartin's Avatar
AustinMartin AustinMartin is offline
Wow! Excited to see this one!
Current Builds
Ferrari Enzo
Ferrari 612
Ferrari F2007
Ferrari 250 Testarossa
"Speed never killed anyone, it the stopping suddenly that kills you"
"With every post they take off me........they take a piece of my heart" PAP 348
Old 12-17-2008, 05:19 PM
roddo roddo is offline
Please please please dont put a V8 in this kit. I beg you to think about putting a little 4 cylinder naturally aspirated screamer in it, otherwise i fear Colin Chapman will be spinning in his box! Like what you've done though chief.
Old 12-17-2008, 05:26 PM
da_ashman's Avatar
Nice work so far, great idea, I also have had a similar idea. Its amazing how small the car is when you compare it to another 1/24 scale car, the wheels are only like 5mm wide!!!! tiny.
Are you trying to Replicate Caterhams Seven RST V8? if so your doing a great job, if not, its a pretty good fluke.
Cant wait to see more
Old 12-17-2008, 11:57 PM
indolene's Avatar
I fully agree that a V8 goes against Chapman's mantra but I went with whatever parts were available and didn't look too ridiculous. (no suitible I-4 or I-6 in my parts box) The Chev indy engine i believe is 2.65l capacity so it isn't too large and doesn't look too out of place.
da ashman: yes the Caterham Levante RST V8 was a big influence in overall concept and sytling of my build, adapted to my preferences. I found some slick tires 8.6mm and 9.7mm wide that scaled up, will be about 205/17 and 235/17 with the same overall height as the stock ones
Here's how the engine sits:
Old 12-18-2008, 06:49 AM
wouter1981 wouter1981 is offline
Well Colin Chapman was a big fan of lightness of his car. And some modern V8's give a verry high output for a small weight and a low centre of gravity, so I don't think Chapman would mind a lot.
Old 12-22-2008, 03:32 AM
indolene's Avatar
some progress, waiting for the temperature to warm up a bit (unseasonal -8C degrees at the moment) before painting the body and finding time between all the Christmas parties
Front shocks with molded springs removed
dashboard CF'd with ScaleMotorsport 1/12 Hi-Def decals and shock with thin solder as springs. Steering wheel a bit too shiny at the moment.
engine painted, awaiting more ancillary parts and detailing. It fills completely without the need to modify the engine bay. The water pump and alternator are donated from my part box and the fan belt is Tamiya masking tape painted black, too bad it is almost completely obscured by the radiator when mounted
Old 12-22-2008, 11:25 AM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
looking good.
where did you get the guage panel from?
SCCA 7, The lost Z
Old 01-02-2009, 06:25 PM
indolene's Avatar
Dash Panel? from a Tamiya mp4/5b kit
Ok , let's try it again. I posted an update earlier with larger images and that seems fine for a few hours then the pictures disappeared. If anyone can help me posting larger pics, I'd appreciate it, thanks in advance.
Here it is again: a quick pic to check the stance and 'overallness'
The seats were painted, CF applied to the back and seat material left over from the Tamiya Bimota Tesi kit applied to the seating area. It gives a subtle two-tone, leather and alacantra look. I'll mash together some seat belts later on
I was originally going to use the wheels as-is for a quick build but as the build progressed, realized I'd never be happy with that. Brake cooling ducts were found and integrated with the existing kingpin/hub and the wheel was opened up
To make room for the steering rod, the hub was split, plastic dremeled away, and glued back together
A lot of fitting and filing but well worth the effort. The ducts will be CF'd
The body color is a mixture of Tamiya X-14 Sky blue and X-1 white enamels. It needs a few more coats and a long drying time before it can be rubbed out.
Old 01-05-2009, 10:35 AM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I love how well you're modernizing this car. The hood louvres, the windscreen... things... the fenders, the motor, and those brake ducts! Awesome! I can'twait to see what you make of it all. Just amazing work.
Old 02-07-2009, 08:53 PM
indolene's Avatar
Thanks, Willimo, for your comments. This is where the project was at the new year, body painted, suspension sorted and waiting for the paint to dry
then disaster involving my impatience at the soft paint and a heat register....yes the tub was badly warped but the hood and cycle fenders were fine so now I've got a partial tub, another full kit parts and some ideas already for another Super 7 build (but let's finish this one first)
It took me a week to find another kit, much longer to get the tub ready and now it's back in track. I took the opportunity to increase the width of the rear fenders by approx 1/16" each side to increase the rear track in line with the increased front width brought on by the added brake ducts
Final color (again) waiting for polishing (again). This is the first time I've used Tamiya enamels and I need to say this paint takes a very long time to completely dry out. It remains soft and very sensitive to handling even after two weeks.
Don't worry about the sloppy black/blue transition, I've already corrected it. I added self-adhesive aluminum tape textured by rolling the handle of a jeweling file as heat reflective engine material
Here, carbon decals added to the rear 'shelf' and details added to the floor. Photo etch plate for the driver and a foot brace for the passenger
Just realized I haven't shown the engine yet! Wires and other plumbing will be added soon.
Progress should be much quicker unless I do something foolish again, installing headers and fabricating the exhaust will be the next task. I haven't decided on what they should look like but I am leaning toward simple, realistic functionality.
Old 02-07-2009, 10:45 PM
Wow! Great build!
Current Builds
Ferrari Enzo
Ferrari 612
Ferrari F2007
Old 02-07-2009, 10:52 PM
Layla's Keeper's Avatar
Layla's Keeper Layla's Keeper is offline
Supermodified
V8's against Colin Chapman's mantra? Guys, you're off your rocker because Chapman was a humongous fan of the Ford 289 V8's that were used in his famous Lotus 30 Can Am car. He helped spearhead development of the DOHC version of the 289 that led to Jim Clark's win in the Indy 500 using the Lotus 38. Not to mention there's the Coventry-Climax 1.5L V8 in the Lotus 25 F1 car and all of those glorious Cosworth DFV's!
I like the way this project's progressing, and I'm eager to see what driveline will get to back up that Indy Chevy.
Proud Owner/Operator of Haven Raceway and Hobby!
Old 02-24-2009, 06:27 PM
indolene's Avatar
I gues we're talking about Chapman's mantra of lightness and not dis-like of V-8s!
Accelerated progress recently, the stock pedal faces were replaced by the ones below, too bad they are almost completely hidden
the headers were painted with Model Master Silver Chrome Trim, an excellent color match to the aluminum tube pipes. They will be 'heat treated' with light mists of Tamiya clear blue, red, and orange later
Looking around for the tube for the mufflers, I decided that the pen insert was right diameter for this build. It took me about an hour of scriblbing circles to use up the ink as to not make a mess when it was cut.
Assorted engine compartment items to be added; battery, fuel filter, random electrical modules, etc...
I had to wait till the engine was mounted before I could fabricate the steering rod linkage. I found a driveshaft CV joint and inserted brass steering rods. Completed the steering rod is has two links and is makes takes a 'Z' path to the steering rack. I'm not sure if this gives any real-world steering feel but this is the only solution given the exhaust headers are in the way. I'm very satisfied with the results, although the CV joint is in the wrong orientation.
Taillamps were modified and shortened from the piece on the left. They will have a bit of shape when completed and not just rectangular. I thought about using round lamps but thought that looked a bit too 'cutesy'
Fender supports fabricated from brass pieces. Not sure how they will be secured to the hubs yet.
The roll hoop on the right was made the first day of the build. Way too FAT...I was going to use thinner aluminum tube for the new one but realized I had two stock Super 7 roll bars from the two kits. Much better. Gussets were added to add detail.
That's it! The engines been wired up and assorted PE parts detailed. The only thing left to do is mount the cycle fenders and take pictures for the 'Completed Projects' Thanks for looking and and any comments are welcome!
