Old 12-06-2008, 05:40 PM
neonnight34609 neonnight34609 is offline
spark plug replacements on a 3.1
after doing my lower intake man gaskets i thought to change the plugs since i was right there .. i replaced the factory plugs with bosh platinum not the fancy ones just the slandered platinum plug . was this the right plug to chose .. the factory ones had 60,000 on them and still looked good.
Old 12-06-2008, 06:18 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: spark plug replacements on a 3.1
As long as they aren't those crappy wal-mart ones with multiple ground electrodes, I think you'll be just fine.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 12-06-2008, 06:19 PM
tblake's Avatar
In God We Trust
BTW, how did the LIM gasket job go?
Old 12-06-2008, 06:24 PM
not as bad as i thought it would be i used a dorman gasket set although it came with everything i needed including new bolts . i didnt think it was of the best quality but still better then the originals .. the plugs where from the parts house .
Old 12-09-2008, 06:27 AM
Highbeamz Highbeamz is offline
The bosch plugs will get you by....but IMO NGK or Delco are best bets...I try to stick to factory replacements for most parts...but that's my personal opinion. I'm running NGK Iridiums, until I switch to Autolite's next year.
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
