Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-19-2003, 07:51 PM
Versus Versus is offline
Check Engine light I30 '98
Hi there,
I searched through this forum but I wasn't able to find any thread with the answer for my problem, I hope someone will be able to helpme.
I bought an Infinit I 30 1998, it works perfectly but I took it to for an oil change and when I got it bakc the Check Engine light was on!!! It doesn't blink but it's permanently on, and I don't want to take it to the Nissan dealer because it will charge me only for take a look!!!
Is there a way to deactivate the light???
Thanks in advanced!!!
Old 06-17-2003, 11:18 AM
Taxvictim Taxvictim is offline
Check Engine Light
My advice is to buy a copy of Haynes Repair Manual for the 1993-2001 Maxima. It has very detailed instructions on how to determine why your check engine light is on. They are too long to re-type and post here. You can also go to www.maxima.org. Good luck.
1996 I-30t, 5 speed. All stock. Black on black.
Old 03-08-2004, 07:51 PM
99i30lmtd 99i30lmtd is offline
check engine
on your pcm (under the console behind the black cover in the driver side floor board) ther is a clpear plastic cover and behind that there is a "gear" that lets a small flat head scredriver fit into it you need to tur your car on and turn the "gear all the way clockwise (i think) if not its counterclock wise but be nice to it because its fraginle. then after 2 seconds turn it bak the other way and it will spit a code to you long and short flashes get the number of long and short flashes and post a reply and ill tellyou the problem cause i have a shop manual for the i 30
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
