Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-19-2003, 06:00 PM
FastTeen FastTeen is offline
turbo and carb ?'s
i was wondering if it would be a good idea to turbochager my car and if it was possible? if so what's the best turbo to use?
also can i put aftermarket carburetors on my dualcarb engine? if so what can i use?
if anyone can help that'll be cool!
95 Ford F250 ext cab long bed Powerstoke Diesel, stock. 92 Ford Mustang LX 5.0: Trick Flow R series intake manifold, Cold Air Intake, Throttle Body, Larger Egr Plate, Flowmasters, 3.73 Gears, Off road H-pipe.
Old 03-19-2003, 07:06 PM
SleeperCivic SleeperCivic is offline
Thumbs up
Hey, nice user name. Sounds like some promiscuous girl.......:flash:
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 03-20-2003, 04:04 PM
and that would mean what?
Old 03-20-2003, 04:08 PM
Go ask your daddy or mommy......
Old 03-20-2003, 04:19 PM
if you think i'm a girl than i'm changin my user name!
Old 03-20-2003, 04:24 PM
No, I don't think you're a girl!! A "fast" teen would mean someone you can get into bed easily, and just happens to be a teen.
Old 03-20-2003, 04:31 PM
ah ****. ok.
you got a answer to my ?'s?
Old 03-20-2003, 04:54 PM
Nope, sure don't. I don't think anyone else does at this point, or they just haven't posted.
Old 03-20-2003, 05:01 PM
that's cool.
Old 03-20-2003, 05:04 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Carburated turbo hmmmm....no.
Old 03-29-2003, 07:09 PM
luckyluciano luckyluciano is offline
hope this helps
To design a reasonable turbo setup, carbonated is not the way to go. Most carb's require some special work in order to get them to function under a blow-through design. Now, I think a carb would be reasonable if it was done like Cody did.(http://ns.netmcr.com/~mdouglas/civic...0_hybrids.html) He's the bottom one. He's got a single sidedraft and it's a pullthrough design, so you don't have the internal pressure issues that are normally encountered with carb's. I don't know specifically about your set up but I know most carb's are a pain.
You can pick up a used Haltech Fuel Injection system for like $600 and do anything you want with it. It's not really that difficult to program, or setup.
If you're really not very afraid of electronics, try the Megasquirt system. It's got much better interfaces than the Haltech, and only costs about $200. The kicker is that you assemble the hardware and install the software (download from online), comes with everything, you just have to put it together.
But The best way to blow-through a carb is to add some sort of fuel enrichment after the carb and leave the jets alone. If you jet the carb for the turbo, the car will run like crap off-boost. The best way to do it would be to run a secondary fuel system with some injectors after/under the carb that are triggered under boost. There's a pretty good little unit here (built in MAP sensor):
http://www.034efi.com/034SupECU.html
The setup won't be cheap though since you're going to have get all the fuel component hard parts (including a secondary fuel tank).
From civic 1200.com
Old 03-29-2003, 07:19 PM
you know it shouldnt be too hard to retro fit a EFI from a newer honda, what engine is that? 2.0L? honda is notorious for interchanging parts over several year spans. do some home work im sure there is something that will bolt right up. and if not your options are to build your own FI or www.force-efi.com run you about $1,500 for a custom built set up. dont get me wrong the carb set up could work but i think it would end up costing more in the end, but if you really wanna go that route try an air cooled VW aftermarket race shop they turbo charge carborated cars all the time. and they could hook you up with some webers too. get rid of the crappy hitachi carbs you got now becuase they wont work for the turbo
good luck
Old 04-01-2003, 08:46 PM
well....i guess i could convert it to EFI, but i would have to get a custom hand made hood becuase it would be stting on top of the engine. there's no extra spacein the engine hold. lucky:um....the 2.0L is the Si engine and i have a 1.8L DX engine that is dual-carb and the Si is FI besides Vtec. also i was thinking of putting a set of Holley "Street Avenger" carb with 770cfm(if they will fit). which in total will give at least a 800HP gain(hehe), est. of corse.
Old 04-01-2003, 08:55 PM
you dont want an holley carb on your import (great for american mussle) get yourself webers if your gonna upgrade the carbs.( are you sure the si in that year is v-tec i dont think so) anyway i think that you can swap the head from a 2.0L accord si engine 90-92 it non Vtec SHOC and use that EFI im alomost positive that the block stayed the same for 6 years but dont quote me let me ask around to see if one of my honda guru buddies knows exactly what years and models swap.
Old 04-01-2003, 10:30 PM
ok i was right the si is not a v tec and you can swap the heads and injection out, The interchange for this is 85-86 Prelude fuel injection, 87 Prelude fuel injected (vin 3), 86-87 Accord fuel injected. It will also fit 88-89 Accord fuel injected if the induction and electrical system is changed.
BS 1.8 12V SOHC 2bbl Carb 1955 98hp@5500rpm 110tq@3500rpm '86 Accord DX/LX (USA)
BT 2.0 12V SOHC PGM-FI 1955 110hp@5500rpm 114tq@4500rpm '86 Accord LX-i (USA)
'86 Prelude Si (USA)
it's the same block
holley 9510 carb ?'s 1980Gbody Engineering/ Technical 1 12-07-2006 10:52 PM
turbo ls hatch ?'s redtegb18b1 N2O | Turbo | Superchargers 4 03-18-2005 08:16 AM
Want to do an LS Turbo have some ?'s YouthfulLad Integra 2 11-27-2004 08:59 AM
