Old 03-19-2003, 04:53 PM
streetrex streetrex is offline
Question wiring harness confusion
alright... I was on hasport's website searching for all the things i need for my b16 into automatic crx project. I looked up the wiring harnesses, and they are 250 beans. Then the next thing i saw was the ecu single wire conversions and their 350 beans. Whats the difference between those 2? are they just the same thing, but the single wire is easier to install?? ------
also, what do i need for the full swap?
this is where i was told to get the engine, and this is what the send with it-
B16A 92-00 (SiR-II) Motor, Tranny, ECU
- Motor
- Hydrolic Tranny (S21, Y21)
- ECU (P30)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
91 crx for sale
automatic
motegi 16"
clear corners and bumper
around 6 1/2 infinity ref.
weapon r coilovers, ingalls camber(front)
very little rust on rear left quarter panel
Old 03-19-2003, 05:02 PM
91zc 91zc is offline
Re: wiring harness confusion
- Motor
- ECU (P30)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
The one wire conversion allows you to hook up a VTEC engine using only one wire as opposed to the 4 required normally.
The hydraulic transmission will not work unless you fab a custom trasnmission mount and use the hydraulic actuation system from a 92+ honda. You will need to buy a conversion harness to further conver the hasport harness to obd1. It would be much easier and cheaper to buy an 89-91 b16a from either a civic sir or integra xsi. You will need a mount kit as well... hasport, hcp, etc. Youl will also need a shift linkage hasport, hcp, or make your own.
If you decide to go ahead with the OBD1(92+ b16a) you will need a cable actuated transmission unless you want to do some fabrication. You will need 90-91 integra rear and driver side motor mount brackets. You also will need the axles and intermediate shaft from the same year integra.
I would suggest getting an OBD0 b16a. It is a much easier swap into the 88-91 civic/crx. Good Luck
91 civic 4dr
b16a
14.8@94
Old 03-19-2003, 06:16 PM
alright now i'm all confused...shit. I didn't know there were more than one type of b16a. god damn... alright, then where can i get the b16a that will fit into my car. don't forget i'm keeping it automatic, so will i need that custom shift linkage?
91 crx for sale
automatic
motegi 16"
Old 03-19-2003, 06:24 PM
Ah, I didn't see that you were going to keep it auto. PM crxlvr on here, he is doing a 1st gen auto b16a into his crx. You won't need the shift linkage obviously since you are going auto. Any engine importer should be able to get you an auto b16a. If you have any more questions fire away. We will try to help you as best as we can.
91 civic 4dr
b16a
14.8@94
Old 03-19-2003, 06:30 PM
thanks man i appreciate it a lot. um, scott(crxlvr) is the dude thats been helping me out a lot. i went to the webpage that he told me to go to, and the engine a listed above is the only b16 i see on the site. so, is that the one i'm looking for?
91 crx for sale
automatic
motegi 16"
Old 03-19-2003, 06:53 PM
www.hmotorsonline.com is where i got that engine info from. but anyway, all i have to do is call up an engine supplier, and just ask for a plain old automatic b16a? nothing about OBD1 or anything like that?
91 crx for sale
automatic
motegi 16"
Old 03-19-2003, 06:55 PM
91civicDXdude's Avatar
"first gen b16"
or
"b16a1"
even though b16a1 technically doesn't exist. the block stamp is just B16A
Old 03-20-2003, 03:52 AM
http://www.hmotorsonline.com/shop/sc...USDM%20Engines
The first engine listed on the above page is a 1st gen b16a. You will need to call them up and ask them to provide you one with an auto trans and ecu.
91 civic 4dr
b16a
14.8@94
Old 03-20-2003, 07:57 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
yeah i called em up and asked if he had the b16a auto tranny cuz im doing the same thing, i plan to call hasport and see if there wire harness is compatible with the auto's cuz they have different plugs and shit, anyway from hmotors my engine was 1500 shipped, but make sure you tell him wether its for a residential addy or business.
if you need more help man, feel free to email me, or pm.
if you need a shop check out www.fullthrottlenyc.com they are in queens and will gladly do the swap for you.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
'09 Sante Fe SE Towing -- Wiring Harness MattInTally MY 07+ 1 12-25-2010 05:49 PM
wiring harness dougb2 Venture 1 11-06-2009 08:10 PM
FS: 2G Radio Wiring Harness & Reverse Harness david-b Classifieds 0 10-02-2006 02:18 PM
90 Si wire harness/ radio wires Hyatus '88 - '91 Civic | CRX | Wagon | Shuttlee 0 08-22-2003 08:29 AM
96 Supra Twin Turbo Wiring harness + trans harness/ automatic twinturboGS The Trading Post 2 04-18-2003 08:11 AM
