Old 03-19-2003, 12:02 PM
cscott784 cscott784 is offline
Send a message via Yahoo to cscott784
1.6 si motor on a dx
Hey all. I have a 90 civic dx hb and got a quote for a used si motor only. Can I just switch my motor with that one, or would I need more mods. Thanks
Scott
Old 03-19-2003, 12:03 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
You can just switch it nice and easy ... but I know everyone in here is gonna tell you to rewire your setup to MPFI
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 03-19-2003, 12:04 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
you can switch the motor, it drops right in. you have a DX which has DPFI you may want to change it MPFI.
My Name is Roberto AKA. Berto
Old 03-19-2003, 12:07 PM
cool! Thanks for the info guys. Do I need a Mechaninc to do this or can I do it myself? Also, is the motor the part that has the valve cover?
Thanks
Scott
Old 03-19-2003, 12:09 PM
Melt's Avatar
depends on how good of a mechanic you are ... personally I have no expirence doing swaps, but a lot of d series people I talk to generally get it done in like a day in the driveway.
AF Bay Area Crew
Old 03-19-2003, 12:13 PM
cool. Is the motor the main component in the engine that has the valve cover? Oh and I dont plan on doing it myself. I dont even know where the motor is...=0)
Old 03-19-2003, 12:20 PM
GTA's Avatar
GTA GTA is offline
Whee..
the motor is from the valve cover all the way down.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 03-19-2003, 12:48 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Okay first off the motor and engine are the same thing. If you don't know where there motor is than you shouldn't swap it, it's cake to swap a D-series for a D-series.
Old 03-19-2003, 06:45 PM
kutsuju racing kutsuju racing is offline
Yes and you do have to change it from Dual Point Fi- to multi point...ther's no way around that your going from two injectors to 4 and there's not that much work in it but by the sounds of it....I don't think you can do it.
if you want I have pics of me building my motor and that's the exact swap that I did...click on the link below and I'm in the Arizona chapter...
Peter S.
www.kutsujuracing.com
Old 03-19-2003, 06:57 PM
GTA's Avatar
GTA GTA is offline
Whee..
you dont have to switch to MPFI, it just recommended. You wont be usuing the full potentional of the stock engine unless you change to MPFI.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 03-19-2003, 07:04 PM
The injectors from the si have a different impedance and that's why you have to use the injector resistor box from an Si or convert over to the P26 ECU...unless your talking about using the DX manifold...
....or why in the Hell would you bother changing over to an SI motor only to put two injectors back on it with that Gay DX manifold? you just waisted about 6 hours of work!
Peter S.
Old 03-19-2003, 07:08 PM
Hatchin Hatchin is offline
Send a message via ICQ to Hatchin Send a message via AIM to Hatchin Send a message via Yahoo to Hatchin
How much of a HP gain is the MPFI conversion?
CRX Si
Old 03-19-2003, 07:13 PM
GTA's Avatar
GTA GTA is offline
Whee..
maybe your current engine is blown, or runs like shit.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 03-19-2003, 07:24 PM
More power to you then Brah
well look at it in the non vtec state DX 92 hp and .1L bigger for the si but .1 lower Compression Ratio with 4 injectors....106? You call it.
and with the vtec your gonna get more out of it. I would not do that swap and put 2 injectors on that motor. Hell if that's the case I have a monifold and stuff I can sell you for cheap....it would be sad to see that kind of set up. if your going through all that trouble you might as well do it right.
Peter S.
Old 03-20-2003, 04:05 AM
Thanks for all the info guys. How much would it cost to switch from DX DPFI to SI MPFI? Also, does the intake manifold come with the motor or would I be using the si's manifold?
THanks
Scott
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
