Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-25-2008, 09:20 PM
pokerdave pokerdave is offline
1999 Venture Blower switch only works on high
I have tried to replace the blower switch on the dash but did not fix the problem. The heat only works on the high setting and thats it. Maybe the motor???
Old 11-25-2008, 09:42 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 1999 Venture Blower switch only works on high
Sounds like it might be the blower resistor. Here is some more info about it and a picture of it's location:http://autorepair.about.com/library/a/1h/bl251h.htm
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 11-25-2008, 10:57 PM
roadrunner2 roadrunner2 is offline
I agree.
The problem with doing nothing is not knowing when you're finished.
Old 11-26-2008, 09:00 AM
db234 db234 is offline
Originally Posted by roadrunner2
I agree.
Me too. I lost speeds 1 and 2. I forget whether it was no fan or the same speed as 3 and higher. New resistor pack did the job. I vaguely remember challenges getting some of the bolts back in place. I had to take the blower motor out. Removing the trim under the passenger side dash gives access. My Haynes manual helped. I didn't realize there were two resistor packs. I'm not sure which I changed.
Old 11-26-2008, 10:36 AM
brcidd's Avatar
brcidd brcidd is offline
Its the resistor module- the back two screws (5.5mm) are slotted to make it easier to replace- no need to pull screws all the way out....thay are a PITA to put back in...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-26-2008, 06:19 PM
Thanks alot for the help... I will check it out asap.
