Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 11-24-2008, 03:28 PM
zzyzzx2 zzyzzx2 is offline
OK to replace rear tires if my front wheel alignment is bad
My back tires are worse than my front, and I still want to replace my ball joints and inner tie rod ends before replacing my front tires and getting an alignment. In so far as I know, my rear wheels alignment is fine, and there is nothing back there that I plan on replacing anytime soon. If I want to get new rear tires, while I get around to replacing all my front end stuff is there any donwside to doing that?
Old 11-24-2008, 03:29 PM
Re: OK to replace rear tires if my front wheel alignment is bad
If it matters, the car in question is an Escort, so assume small FWD car.
Old 11-24-2008, 05:48 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
The rear tires will not be affected by a front end alignment. However, being a small unibody vehicle, I would get a 4 wheel alignment in the near future.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-25-2008, 08:11 AM
I will once I get all my front end stuff done:
Inspect transaxle seals, and possibly replace.
Replace ball joints.
Replace inner tie rod ends.
Install camber bolt(s).
Replace front tires (replace rear tires too, unless previously done)
Then get an alignment.
