Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Interior
Interior This is the place for all interior modifications.
Old 11-19-2008, 10:01 PM
big dwag big dwag is offline
Gauges
I have a 87 camaro, the problem i'm having on the inside is the fuel, rpm,oil, & battery gauges don't work. the fuel gauge stays on full when its empty, the rpm gauge jumps over to 7000 and stays there, the oil gauges stays on 60, and the batt gauge works when its running but shows a low charge with a new batt and alt. Fuse's are good on the inside of the car. Is there any other fuse's on the car?
Old 11-22-2008, 04:25 AM
goldz28's Avatar
goldz28 goldz28 is offline
Re: Gauges
Could just be your instrument cluster
Old 11-22-2008, 05:01 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Gauges
that or bad body or engine grounds. if it was a fuse, none of the needles would move at all.
Old 11-25-2008, 04:20 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Gauges
another vote on cluster here, pull it and clean the contacts where it plugs in, then try it again
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 06-02-2009, 08:39 PM
rasmith5277 rasmith5277 is offline
Re: Gauges
I have an 85' Camaro (V6) and I'm looking to upgrade my cluster from the stock V6 (speedometer, Gas gauge and red gauge lights) to a Z28 or IROC gauge cluster. What will be needed to make the upgrade? Are there any electrical modifications necessary?
Old 07-19-2009, 02:48 PM
CamaroIROC88350tpi CamaroIROC88350tpi is offline
Post Re: Gauges
On my 88 Iroc Camaro my temperature gauge is stuck at the very top. It won't go down. The 2nd day I bought it I wanted to rev up my baby & when I did the temp gauge just stuck up there. My other gauges work properly but this is aggravating because I can't ever really know what the temp is in my engine. Any advice on this will be thanked.
Email me personally @ [email protected] or reply on here to the post. Thanks!
Old 07-19-2009, 03:05 PM
Genopsyde's Avatar
The President
Re: Gauges
probably the gauge sender, should be located on the intake manifold somewhere with a single green wire attatched.
Old 07-19-2009, 03:21 PM
Re: Gauges
Ok. Where is the location of the intake manifold?
