Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-01-2008, 07:25 AM
Brock81 Brock81 is offline
1999 C custom climate control issue
My 1999 century custom 3.1 has the dual inside climate temp control, one main(I guess) and a passengerside slider control. every now and then, the control does not respond. For about two weeks this summer, the A/C would only blow hot, even thogh set on cold.Then one day it started responding to the setting. this has happened a few times. What can I expect to have to replace?
Old 10-01-2008, 09:08 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1999 C custom climate control issue
Was this on both passenger and drivers sides? Has the problem re-occurred? How is the heat on both sides?
On A/C cooling issues the first thing to check is whether the compressor is engaging. When was the last time the A/C was serviced? Check for a low refrigerant charge.
Timeslip 08/12/06
AF Community Guidelines
Old 10-01-2008, 10:14 AM
Thanks for responding
This always occurs on one side or the other at a time. This malfunction has never occurred, to my knowledge, on both sides simultaneously. When the controls are responding, the AC works well. (This car is primarily driven by my wife)
Old 10-01-2008, 09:12 PM
stripe stripe is offline
Are you sure both controls are set to the same temp?
You may have hot air on one side and cold on the other if not set right.
Cheers
Stripe
