Old 09-30-2008, 04:28 AM
gatoratoy227 gatoratoy227 is offline
99 GP with odd front end noise
my wife has a 1999 GP when she goes over speed bumps the front suspension makes a metallic scrape it sounds like trying to drill through a mild steel billet a very high pitched scrape
i know the car has 4 wheel struts i think mcpherson does it have a lower ball joint or no i know some front end strut set ups still have a lower ball joint or will i be better off replacing the front struts
i have the feelng that its a strut thats gone sour
any ideas?
NO! ,we can't stop here, this is bat country. Raoul Duke
Old 09-30-2008, 07:58 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 99 GP with odd front end noise
The first thing I would check is for a broken/cracked front stabilizer bar, pretty common issue on these cars. If that checks out, I would look at the lower control arm bushings and struts.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-30-2008, 10:27 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Here's a picture of how mine broke. It almost didn't appear broken, but once I took the endlink off, the two peices came apart.
I replaced it with a ZZP GMPP one, it came with new endlink bushings and midpoint bushings.
http://www.automotiveforums.com/vbul...d.php?t=904243
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-30-2008, 10:39 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Its been a good month for broken sway bars! The lower control arm front bushings are pretty common as well. You will see the rubber part pushed out of the control arm and sometimes the control arm resting on the sub frame if there really bad.
Old 09-30-2008, 11:14 AM
BNaylor's Avatar
BNaylor BNaylor is offline
It would help to post the current mileage on suspension issues.
Timeslip 08/12/06
AF Community Guidelines
Old 10-01-2008, 02:27 PM
almost 140,000 miles on the car and its been doing this for about 2000 miles now give or take i'm just worried about some thing happening to the car which may cause her to lose controll of it she drives about 10 miles to work almost every day and 20 miles to school every monday and wednesday intrestate miles and as i said i don't want anything to happen to her
