Old 09-21-2008, 06:06 PM
KyMDLR's Avatar
KyMDLR KyMDLR is offline
Alternative's to K&N filter?
I have an 05' GT v6. I have been looking to upgrade the air intake, but would like to get away from spending $350+ on the K&N if at all possible. I was thinking of trying to make my own with some parts from autozone. Anyone know of any alternatives?
I saw this on Ebay, http://cgi.ebay.com/ebaymotors/99-05...mZ110290527730
Old 09-21-2008, 06:49 PM
Highbeamz Highbeamz is offline
Re: Alternative's to K&N filter?
The problem I've found with short ram intakes (and I know from experience) is the intake air is too hot. You gain CFM from the filter but you lose power from the increased intake air temperatures. On a 30*C day, sitting at a light, I could see temperatures anywhere from 125*F to 185+*F depending on how long I idle. I built a cold air box (which takes air from the fenderwell, it's fully insulated) and I now see cruising temps only about 10 to 15* above ambient temps (maybe better at times) and I have never seen the air intake temps go much above 100*F even at lights, not even 110.
Food for thought.
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 09-21-2008, 07:57 PM
BNaylor's Avatar
BNaylor BNaylor is offline
I agree. Cheapy short ram air intakes are a waste of money. The one shown at the EBay link is for a 3100/3400 V6 engine although the pic shows a Series III 3800. There is no thermal/heat insulating shield and the other problem with that setup shown is water intrusion due to a lack of enclosure. It is placed right behind the driver's side headlight where there is an opening to take advantage of airflow and the high pressure area. That setup is fine with the stock airbox. However, when the intake system due to a poor design or improper installation sucks in water the engine may hydrolock.
There are plenty of effective aftermarket CAI/FWI air intakes other than the cheapies on EBay and the K&N brand for the '04 and up GP.
See links below:
Thrasher CAI
MSP CAI
Wizaired CAI
Here is a custom true fender well intake (FWI). The cone filter sits underneath the driver's side fender.
Timeslip 08/12/06
AF Community Guidelines
Old 09-22-2008, 12:14 AM
I might snap some pics of my cold air intake setup when I remove it to install my replacement PCM...just to give ideas...it's a LITTLE cheezy and not as pretty as a store bought CAI but it's fully functional.
14x,xxxkm's
Old 09-22-2008, 09:43 PM
BNaylor's Avatar
Cheezy?
Regardless, I'd like to see it.
Timeslip 08/12/06
Old 09-23-2008, 12:09 AM
Originally Posted by BNaylor
Cheezy?
Well, the outside is wrapped in heat insulating tape (that aluminum stuff) as is the coupler...I figured anything to resist heat is good.
Today I was getting 4*F above ambient temps cruising at 60km/h...
I'll have pics up this weekend, I likely won't get the PCM in til Friday if it takes the same time to get here as it did last time.
14x,xxxkm's
Old 09-23-2008, 09:19 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
what brand PCM did you go with?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-23-2008, 08:24 PM
I went with Intense...
14x,xxxkm's
