Old 09-04-2008, 03:47 PM
Vinz00GT Vinz00GT is offline
cranks and nothing
2000 GP GT was running good then took off radiator cap before it was fully cooled and got that corner of engine wet. Then would not start. Does it just need to dry out or what other possible things could have happened? What can't get wet on that side of engine? Sensors? Ignition coils? Wires? It cranks and cranks but no fire. Thanks
Oh, also it won't come out of park. I did get it to but don't know how and now its stuck in park still.
Old 09-04-2008, 09:00 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: cranks and nothing
Nothing. Everything should be able to handle a little moisture. How much coolant did you lose?
Check and make sure you have spark by removing the plug wires from the coil packs and cranking the motor. You should see sparks jumping across the coil terminals.
If you have spark, check for proper fuel pressure.
Maybe also try unplugging the MAF sensor and attempting to start the car. Maybe its just a fluke that it happened just as you spilled some coolant.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-05-2008, 01:48 PM
Any tips on replacing fuel pump and relay? Thanks.
Old 09-05-2008, 03:36 PM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
drop fuel tank to replace pump recomend replace strainer and fuel filter.
Do u have fuel pressure?
Old 09-05-2008, 04:28 PM
Question Re: cranks and nothing
No. No pressure. I picked up a relay and fuel filter but still shopping around for a pump. Need to have fixed by Monday so any tips would be appreciated. Oh, the not get in gear thing was cuz I wore the battery down trying to get it going when it broke down. Thats not a problem now. Also I need to replace the crankshaft position sensor. What's the easiest way to get the serp. belt off and then the pulley?
Thanks
Old 09-05-2008, 04:50 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Time out. There is no requirement to drop the gas tank to replace the fuel pump in a '97-'03 Grand Prix. There is an access cover in the trunk behind the rear passenger seat.
Visit the Tips & Maintenance forum on fuel pump removal. See link below.
Fuel Pump Replacement
Timeslip 08/12/06
AF Community Guidelines
Old 09-05-2008, 06:54 PM
BNaylor's Avatar
The_Mechanic_33,
Thanks for contributing to the forum but sorry due to US copyright law, GM's copyright of their TSBs which are technically proprietary in nature and AF's policy against posting copyrighted material we do not allow posting of GM TSBs verbatim therefore you will have to edit it or remove it. If not edited in your own words or removed the TSB info as posted will be removed for you. The same is applicable to any information posted directly or verbatim out of a GM factory service manual. If it was legal we would have just about every TSB GM has out on the Grand Prix posted at our Tips & Maintenance forum. Your cooperation is appreciated.
See our guidelines below.
Warnings and Bannings:
Not adhering to these guidelines can result in your account being temporarily or permanently banned. The length of the banning depends on the severity of the guideline broken. During temp bannings a member may not post under any other account. If this happens and it is discovered, all accounts belonging to that person will be banned permanently.
The following situations can possibly get you warned and or your account banned:
1. Ignoring moderator's warnings for any of the items outlined in this document.
2. Heavy personal insults (includes racism, sexism or any other ism's).
3. Campaigning to bring back a banned member, whether in your posts or in your signature.
4. Criticizing a moderator's decision openly in the forum.
5. Making constant attacks on other members and moderators, aka, trolling.
6. You are underage.
7. Post Whoring.
8. Making an Alias Account.
9. Posting pornographic, sexually offensive, sexually explicit or objectively material.
10. Failing to learn from a previous suspension.
11. Impersonating another individual by creating an account that looks very similar to that member or by other means.
12. Having an offensive account name.
13. Scams or the promotion of scams.
14. Advertising other forums when asked not too.
15. Posting of copyrighted material and illegal software.
16. Continuously bumping up threads.
Note: The same is applicable to AllData subscriptions. Check the terms or service concerning posting of copyrighted material. Unless you can show otherwise that you are allowed to do so AllData does not allow reposting as seen here. See below.
ALLDATA LLC Legal Notices and Trademarks
Introduction
ALLDATA LLC ("ALLDATA") makes available information, materials, and products on this Web site, subject to the following terms and conditions. By accessing this site, you agree to the terms and conditions as outlined in this legal notice. ALLDATA reserves the right to change these terms and conditions from time to time at its sole discretion.
Copyright; Limited License
The information on this Web site is protected by copyright:
© 1996-2008 ALLDATA LLC All rights reserved.
Except as specifically permitted herein, no portion of the information on this Web site may be reproduced in any form or by any means without the prior written permission from ALLDATA.
1. OWNERSHIP, LICENSE & RESTRICTIONS ON USE
1.1 All right, title and interest (including all copyrights, trademarks and other intellectual property rights) in this Site belongs to ALLDATA LLC. In addition, the names, images, pictures, logos and icons identifying ALLDATA's products and services in many countries are proprietary marks of ALLDATA LLC and/or its subsidiaries or affiliates. Except as expressly provided below, nothing contained herein shall be construed as conferring any license or right, by implication, estoppel or otherwise, under copyright or other intellectual property rights.
1.2 You are hereby granted a nonexclusive, nontransferable, limited license to view, reproduce, print, and distribute insignificant portions of materials retrieved from this Site provided (a) it is used only for informational, non-commercial purposes, (b) you do not remove or obscure the copyright notice or other notices. Except as expressly provided above, no part of this Site, including but not limited to materials retrieved therefrom and the underlying code, may be reproduced, republished, copied, transmitted, or distributed in any form or by any means. In no event shall materials from this Site be stored in any information storage and retrieval system without prior written permission from ALLDATA LLC..
1.3 Use, duplication, or disclosure by or for the United States Government is subject to the restrictions set forth in DFARS 252.227-7013 (c)(1)(ii) and FAR 52.227-19.
2. LINKING
You may provide hyper links to this Site (from yours) provided (a) you do not remove or obscure, by framing or otherwise, advertisements, the copyright notice, or other notices on this Site, (b) you give ALLDATA notice of such link by sending an e-mail to [email protected], and (c) you discontinue providing links to this Site if notified by ALLDATA.
3. DISCLAIMERS
3.1 THIS SITE IS PROVIDED ON AN "AS IS", "AS AVAILABLE" BASIS AND ALLDATA EXPRESSLY DISCLAIMS ALL WARRANTIES, INCLUDING THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, AND NONINFRINGEMENT.
3.2 ALLDATA disclaims all responsibility for any loss, injury, claim, liability, or damage of any kind resulting from, arising out of or any way related to (a) any errors in or omissions from this Site and its content, including but not limited to technical inaccuracies and typographical errors, (b) any third party websites or content therein directly or indirectly accessed through hot links in this Site, including but not limited to any errors in or omissions therefrom, (c) the unavailability of this Site or any portion thereof, (d) your use of this Site, or (e) your use of any equipment or software in connection with this Site.
4. LIMITATION OF LIABILITY
A COVERED PARTY (AS DEFINED BELOW) SHALL NOT BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, OR CONSEQUENTIAL DAMAGES OF ANY KIND WHATSOEVER (INCLUDING, WITHOUT LIMITATION, ATTORNEYS' FEES AND LOST PROFITS OR SAVINGS) IN ANY WAY DUE TO, RESULTING FROM, OR ARISING IN CONNECTION WITH THIS SITE, INCLUDING ITS CONTENT, REGARDLESS OF ANY NEGLIGENCE OF ANY COVERED PARTY. "Covered Party" ALLDATA, its affiliates, and any officer, director, employee, subcontractor, agent, successor, or assign of ALLDATA or its affiliates.
5. PRODUCT & SERVICE AVAILABILITY IN FOREIGN COUNTRIES
This Site may contain references or cross references to ALLDATA products and services that are not available in every country.
6. GOVERNING LAWS IN CASE OF DISPUTE; JURISDICTION
These Terms and Conditions shall be governed by and construed in accordance with the laws of the State of California, USA, as they apply to agreements made and solely performed therein. Disputes arising hereunder shall be exclusively subject to the jurisdiction of the Federal Courts of the United States of America and/or the State Courts of California and jurisdiction therefor shall rest solely in California, USA.
7. CHANGES TO SITE AND THESE TERMS AND CONDITIONS
This Site and these Terms and Conditions may be changed by ALLDATA with or without notice. Please review this link on a regular basis for changes. Continued use of this Site following any change constitutes your acceptance of the change.
8. ENTIRE AGREEMENT; SEVERABILITY
These Terms and Conditions incorporate by reference any notices contained on this Site and constitute the entire agreement with respect to your access to and use of this Site. If any provision of these Terms and Conditions is unlawful, void or unenforceable, then that provision shall be deemed severable from the remaining provisions and shall not affect their validity and enforceability.
9. FEEDBACK; CONFIDENTIAL INFORMATION; PRIVACY
Please note that, with the exception of credit card numbers, ALLDATA does not want to receive confidential or proprietary information from you through our Web site. Any non-personal information or material sent to ALLDATA will be deemed NOT to be confidential. By sending ALLDATA any non-personal information or material, you grant ALLDATA an unrestricted, irrevocable license to use, reproduce, display, perform, modify, transmit and distribute those materials or information, and you also agree that ALLDATA is free to use any ideas, concepts, know-how or techniques that you send us for any purpose. However, we will not release your name or otherwise publicize the fact that you submitted materials or other information to us unless: (a) you grant us permission to do so; (b) we first notify you that the materials or other information you submit to a particular part of a site will be published or otherwise used with your name on it; or (c) we are required to do so by law. To learn more about how ALLDATA protects your personal information, such as your name and address, please refer to the ALLDATA Online Privacy Statement.
10. TRADEMARK INFORMATION
The trademarks, logos and service marks ("Marks") displayed on this Web site are the property of ALLDATA or other third parties. You are not permitted to use the Marks without the prior written consent of ALLDATA or such third party which may own the Marks. "ALLDATA" is a registered trademark of ALLDATA, LLC.
11. IF YOU DO NOT AGREE...
IF THESE TERMS AND CONDITIONS ARE NOT ACCEPTABLE IN FULL, YOU MUST IMMEDATELY TERMINATE YOUR USE OF THIS SITE.
http://www.alldata.com/trademarks.jsp
Timeslip 08/12/06
Old 09-05-2008, 07:20 PM
tblake's Avatar
In God We Trust
Go here for procedures to replace the crank position sensor.
http://www.automotiveforums.com/vbul...d.php?t=652664
to get the belts off, I usually use a 15mm socket on a 1/2 inch breaker bar. Its usually the easiest tool to get in there that gives enough leverage to put some slack in the tensioner. removing the coolant overflow bottle and placing aside the fuse box also gives more room.
Old 09-06-2008, 07:13 PM
Thanks for the help. I'll be starting soon I hope. Let you know how it goes.
Old 09-07-2008, 01:19 PM
Ok fuel pump went in relatively easy. But I do still have the issue of it being almost impossible to press the button in on the gear shift to get out of park or to put in any gear for that matter. What causes this? How do I fix or bypass? Thanks.
Old 09-07-2008, 03:21 PM
I do Apologize I should have read the rules and relised the copyright infringment policies I was breaking.I will reword my posts.
Old 09-07-2008, 07:13 PM
BNaylor's Avatar
Not a major problem. It happens periodically especially if you are an auto tech or mechanic that happens to have subscriptions to the various resources available. Even the regular auto enthusiasts do it inadvertently. I realize it is easier to post a TSB or a tech procedure out of the FSM then a lengthy reply and embedding images. However, as you can see that is questionable practice and our Admins have established rules against it. All the Moderator does is enforce the rules. Thanks for the reply and apology. And thanks again for contributing to this forum.
Timeslip 08/12/06
Old 09-18-2008, 07:02 PM
Well i have got so much from this forum the least i can do is help here and there.
