Old 08-29-2008, 05:14 PM
Zubski's Avatar
Zubski Zubski is offline
Ferrari FXX 1/24
Hello
Next build, Ferrari FXX. Time to slow down, i built my other models to fast Grade 10 starts tuesday so i guess that work slow me down also.
I know the exaust doesn't have orange rust on it, but i had a weathering set that i really wanted to use
And a picture of more weathering
Enjoy,
Zubski
Old 08-29-2008, 06:30 PM
Zachary Zoomy Zachary Zoomy is offline
Re: Ferrari FXX 1/24
very nice! I'm going into grade 10 to.
Old 08-31-2008, 01:37 PM
Zubski's Avatar
Thanks Zachary.
This was the first kit i beleive i owned, i started it about 2 years ago and just got back to it. The body was painted but needs to be stripped. Some parts were primed with grey primer some parts got no primer and it just doesnt look right. So into CSC it goes.
Nearly completed the engine now.
Front uprights are complete.
Zubski
Old 09-03-2008, 06:51 PM
Zubski's Avatar
Update:
Zubski
Old 09-03-2008, 08:07 PM
NissanSkylineGTR98's Avatar
Nice work on the front axle assembly. Any idea what colour the body will be? Keep up the good work
Steve
Old 09-03-2008, 11:54 PM
rockinanko's Avatar
rockinanko rockinanko is offline
Hi, so you're gonna strip the body raw again?
be careful on what you use to do the stripping, tamiya plastic can be brittle in some areas...also, if you want a complete color matching paint, be sure to strip it very clean.
i have not start anything on this kit so i don't have much advice to give here, as a rule of thumb...the more openings the body houses, the more complex the final fitting will be.
the previous enzo kit has some issues of the doors can't fully flushed & was left in open state to display instead...you can read more on this in those tamiya enzo builds here...
good luck!
I can feel the adredalin,
the same adredalin of what it's like...
to be a classic ferrari coachbuilder.
Old 09-13-2008, 12:39 PM
Zubski's Avatar
Hello
Paint is stripped from the body. Spent alot of time sanding after to get it ready for new paint. I will probably use Bright red.
Here you can see a picture of before sanding and after.
I have been alittle busy with the Kawasaki ZZR1400, very fun kit. I would post a wip but i already have two going right now and i don't think you would want to see anymore
Paint should go on soon.
Old 09-14-2008, 03:12 AM
rockinanko's Avatar
Hi zubski,
i hope you don't mind me saying this, if you keep sanding down those body parts...you'll lose quite alot of panel lines /details in the process.
i suggest you stop doing it & soak the whole thing into used brake fluid for a day or so instead. i can strip my damaged paintworks in it, so clean that all i need to do is use a toothbrush & brush away those peels.
give it a try...
Old 09-14-2008, 02:22 PM
JohnnyFerrari's Avatar
JohnnyFerrari JohnnyFerrari is offline
Great Wrok Zubski! Impressive keep it up
Old 09-20-2008, 09:38 AM
jtwisconsin's Avatar
jtwisconsin jtwisconsin is offline
Brake fluid and I have a love-hate relationship....I love how it strips paint, but I hate having to use it because it means I screwed up again.
Seriously though I would pick some up and try it. I think you will be very happy with the results.
Old 09-21-2008, 12:52 PM
rockinanko's Avatar
it's ok bro...brake fluid is not the best method though but used fluid is free, just drain it from your car when you're changing for new fluid.
i made many costly mistakes too...now i know some plastic (those older kits) can't use brake fluid as they will become very brittle. i learnt through paying tuition fees (mistakes like this) too!
hehe...
