Old 08-27-2008, 09:50 AM
TDI owner TDI owner is offline
2002 Jetta TDI Error Code P0128
I have this error code on my TDI (P0128) and I cannot find out what it means.
Old 08-27-2008, 07:53 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2002 Jetta TDI Error Code P0128
Welcome to the forum!
Have you tried searching the appropriate VW Jetta forum? This appears to be a pretty common issue with the 2001 and 2002 Jetta, and appears to point to a bad CTS or connection to the CTS. It appears most people have issues with aftermarket CTS, but OEM work fine.
It also appears that VW issues a TSB addressing this common issue. The VW Jetta forum will probably have more details for you.
-Rod
Old 08-27-2008, 09:55 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
http://www.obd-codes.com/trouble_codes/volkswagen/
According to this site its Long Term Fuel Trim B1 System Too Lean.
Not busting chops, but that took a google search and one click
Dragging people kicking and screaming into the enlightenment.
Old 08-28-2008, 06:40 AM
shorod's Avatar
SHO No Mo
Check that again, what you looked at was for P1128.
But, agreed, I did a quick Google to find a multitude of information on the P0128 code, and I suspect much of the same information could also be found in the VW Jetta forum on this site.
-Rod
