| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Turbo/Engine Help
Ok I am looking to get over 300hp(but the more the better) out of a 1.8L, 4 Cylinder, its in a Mini Cooper. I would like input on what I need to do to the engine and what products to get so that I achieve this HP in a daily driver. Money is not too much of an issue. All input is greatly appreciated. Thanks
Re: Turbo/Engine Help
Welcome to the forum!
If money is not much of a factor, why not trade in your non-S for a Cooper S, then get an aftermarket chip for it. Or check with the Cooper enthusiast groups to see what they are doing. Since you're asking questions specific to a particular car and not "how does a turbo charger work," you should likewise be posting these questions on the forum specific to your car. -Rod |
A T25 will be too small for starters. Even with a T3-60 trim compressor wheel (the biggest you can fit on a T25 center section), they max out just a bit over 300hp
You will need a T3/T4 hybrid most likely, or in modern Garrett terms, one of the larger GT28's at least As for engine stuff, I don't know the details of the coopers, but I'm sure there are forums where people have been down this road and could give you very good info. You want forged pistons, for example, if you are going to be aiming for impressive boost numbers and will likely want to drop your compression ratio while you are at it. Might need rods also I can't say I'd use an aluminum flywheel with a turbo
life begins at 10psi of boost Three turbo'd motorcycles and counting.
I'm generalizing
Hmm, I ask because I was thinking of getting a Fidanza for my project car. I don't intend to do much drag racing in the car but I do want to ato-x it and take it to the local road course once in a while. I though the lighter flywheel would suite that. However, I've been mixed opinions on whether I should stay stock or go with the lighter one.
The dilemma continues. |
Not saying that lightening the flywheel is completely useless, but it is given far more attention than it deserves. There are much much more impressive things you can waste your money on that will get you far better results, performance wise. Bang for the buck and all that. If money is no object and reliability is irrelevant, then knock yourself out, of course, but go all the way, if you're going to do that, and shave the crank. Can usually lose a lot more weight at the crank than the flywheel
Ah, I see your point. This is NOT going to be a track car and it won't be a DD but I still don't want to have to worry about a flywheel that could separate on me.
Thanks for the advice. That's about $400 extra bucks I can put into a Quafie. |
People go nuts over flywheel weight. The point is to match it to the vehicle weight and engine torque. They can affect performance, but they are simply energy storage devices. If they're too heavy they can eat up some acceleration, but if they're too light it won't help. There is nothing more frustrating than driving a car with too light a flywheel.
well... trying to get a date with the new girl in the mailroom is pretty frustrating too. As far as the original question... its pretty vague. That's like saying, "I have money - what car should I buy?"
Dragging people kicking and screaming into the enlightenment. |
With out going through too much trouble there is many different bolt-on options that will increase hps...but if a turbo is what the doctor ordered...then to get the most out of it it's best to use a intercooler in the system. Besides an intercooler looks cool if you mount it in a underbody kit.
Well, that really depends on the turbo, how much boost you run, compression, and timing. The only way I wouldn't use one is if I were running VERY low boost. Personally though, who buys a turbo to run 5 PSI? If you're going to go with a turbo, get an IC.
The problem with turbos is they don't really provide good power numbers unless they run around 8 psi polygon is right if you don't run that high of numbers get a chip. Jet performance products seem to be popular
I just don't want to get screwed at the engine shop that is all, so the more info I get in here will help me whan I go to the shop
Yes,it is a common way to increase the power with a turbo ,but there are still two thing need to be consider ,the first thing is the pressure the second thing is the coolant. If you add a turbo system on you car ,maybe you should pay attention to anothe thing,noise.
And heat. We had a Mini Copper S in at work a couple weeks ago. I'm amazed that didn't melt anything with the standard blower. It's a very small engine bay to pay a lot of power. 300bhp in a Mini is nigh on suicide.
Seatbelts Saved My Life
