Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 08-22-2008, 06:05 PM
renegade295 renegade295 is offline
95 3.0L running rich after overhaul
I have a specific issue that I havent been able to find in past post.
I had a bad injector on the right back of my 95 villager. Figured if I was going that deep I would go ahead and rework the heads and replaces gaskets and timming belt. Everything went well until final re-assembly. Started right up but would not accelerate, seemed to checked out perfect. Then I noticed that in my haste I reversed the plugs for the TP and MAF. After switching back it would not idle but reved perfect. Assumming I damaged the MAF or TP I replaced both.
The T/P was used but the MAF is new. Doesnt set the light but after taking for a 5 mile drive it set the MAF code again. But no light and no other codes.
Still will not idle and blows black smoke on acceleration. ( running very rich ) If I unplug the MAF it idles perfect but obvioulsy stalls on acceleration. I also verified there is no vacum leak.
Also during the 5 mile drive the van shifted very late and very harsh, wich is why I am wondering if the junk yard T/P sensor is bad.
Could the T/P be bad and not set a code? Could I have damaged the ECM?
Or did I miss something else along the way?
Any help would be greatly appreciated.
Old 08-23-2008, 07:52 PM
tempfixit tempfixit is offline
Re: 95 3.0L running rich after overhaul
I would double check the TPS. What did you set your timing at? I believe it should be 17 degrees.
Old 08-24-2008, 08:18 AM
Problem solved.
I was leaning toward the T/P, but wasnt positive. So I found the post giving directions on downloading the nissan service manual. I downloaded on my laptop and then went out and start checking voltage and resistance on everything.
The only abnormal thing I found was low input voltage on the hard stop T/P. So, on a hunch I called around and found a used ECM. $30.00 After installing the ECM the van is running perfect.
I obviously damaged the original ECM by reversing the T/P and MAF plugs. Which makes sense after I went through the test procedure for both components. the T/P has a 5volt input, while the MAF has a 12 volt input. And the MAF's 12 volt input is in the same plug pin as the T/P's return signal position. So sending 12 volt back to the ECM in place of a 5 volt max return signal probably isnt a wise choice.
Any, problem solved and van is running great now.
