Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-19-2008, 12:52 PM
tsleber3 tsleber3 is offline
2001 Buick Regal LS electrical problem.
I have '98 Century, a '01 Regal and a '08 Lucerne. Love 'em all!
The '01 Regal has lost power to the cig lighter and assessory power jack.
The E5 fuse in the I/P block is good. There is power going into the orange
wire at the fuse block but it isn't coming out at the connector in the center
console. It looks like I will have to pull the carpet to get at the wiring
harness. How is the carpet installed? Is it possible to get it out and back in
neatly.
Thanks,
This is a great forum!
IHS,
Ted Leber
Old 08-19-2008, 08:39 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2001 Buick Regal LS electrical problem.
Do you have a good ground on the lighter/accessory socket?
Old 08-19-2008, 10:02 PM
BNaylor's Avatar
BNaylor BNaylor is offline
How far did you dismantle the console to determine you need to remove carpeting? Last time I checked you can see the wiring harness and electrical connector that feeds the 12 volts and ground to both receptacles as long as the door is open and ashtray removed as a cursory inspection.
Timeslip 08/12/06
AF Community Guidelines
Old 08-21-2008, 01:45 PM
The console is sitting on my work bench.
I used a needle probe on my DVM to penetrate the wire nsulation where
it disappears under the carpet. No voltage there. I'm losing it between
there and the fuse block. I need to get under the carpet but I don't want
to mess it up.
IHS
Ted Leber
Old 08-21-2008, 01:47 PM
Yes, That was my second check.
IHS
Ted Leber
Old 08-21-2008, 04:04 PM
BNaylor's Avatar
IMO most likely at or towards the dashboard (right) fuse block assembly since that has been a known issue for some Regal and Grand Prix "W" body car owners. I recall corrosion issues or wiring directly at the fuse block.
Note: Until that is fixed I believe you will be missing 12 volts to the ALDL odb-ii port so a typical odb-ii scanner will not work if it needs to power off the port.
Timeslip 08/12/06
