Old 08-18-2008, 05:59 PM
Capnjeff Capnjeff is offline
2001 GA Blower/Switch issue
Hi,
This is my first post. I bought an '01 GA for my daughter yesterday. It has a few minor problems. I'm currently replacing the brakes lines and the fuel lines. I also noticed that the blower motor operates only on setting "5". There are a lot of smart people on here who can probably point me in the right direction. Should I look at the switch, the motor itself or a resistor? Thanks in advance for your help... Jeff
Old 08-18-2008, 09:27 PM
doctorhrdware doctorhrdware is offline
Re: 2001 GA Blower/Switch issue
The blower motor resistor is bad.
Old 08-18-2008, 10:25 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF Capnjeff !!
Yes it sounds like the resistor, here is a link with the procedure.
Blower Motor & Resistor Removal - 99+ Grand Am
1999 Grand Am SS 3.4 OHV
Old 08-19-2008, 08:36 AM
Awesome, thanks a lot. I am working a 48 hour shift at present. I'll start on it on Wednesday. Thanks again...
Old 08-19-2008, 08:39 PM
Or you can get a small extension, that has a swivel included for the socket connection on the extension. It made much easier for me, I also took out the front seat. That way I could lay down, much easier on my broken back.
Old 08-20-2008, 02:02 PM
Yes it can be hell on the old back!
On thing the insulation and rubber mat on the fire wall is kinda thick and in the way, compressing it several times should give you a little more room as with removing the blower.
