Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-20-2007, 05:07 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Thumbs up Blower Motor & Resistor Removal - 99+ Grand Am
Blower Removal
- You will need a 1/4" driver/ratchet, 7mm socket, 3" extension, and a swivle joint makes things easier.
- First disconnect the battery.
- Remove the lower kick panel on the passenger side floor board.
- Three 7 mm screws hold it on.
- Here is a pic of that.
- lower kick panel
- If removing the blower motor you will also have to remove the glove box.
- Or you can slide the body control module(BCM) to the right ,
then you can access the remaining screw.
- To remove the glove box(GB), thier are five 7mm screws holding it on.
- Open GB door.
- Remove those, slide GB forward slowly, then reach on top and uplug the GB lamp wire harness.
- Three 7 mm bolts(circled in red) hold blower motor in place too.
Removing/Replacing Resistor
- Here is a pic of the resistor plug area.
- Unplug before attempting to remove.
- Remove the Two 7 mm bolts holding resistor in place(circled in red).
- swivle comes in handy here-
- Pull resistor straight down to remove.
- Here is a pic of the old verses the new resistor.
- Install in reverse procedures.
- TIP #1- If you are replacing the resistor you may want to remove the blower motor for easier access to the resistor, which is behind the blower against the firewall/floor board.
- Tip #2 - laying your floor mat over the doorway opening makes it more comfortable on your back!
* not responsible for chiropractic needs after this job
1999 Grand Am SS 3.4 OHV
Old 04-18-2007, 12:38 PM
drstroud's Avatar
drstroud drstroud is offline
Re: Blower Motor & Resistor Removal - 99+ Grand Am
Just FYI, the NAPA part number is ECHBR82. I just ordered one.
2007 G6 V6
Old 11-21-2007, 11:45 AM
road_rascal's Avatar
road_rascal road_rascal is offline
Send a message via Yahoo to road_rascal
Thanks for the writeup. I have to do this repair on my sis-in-law's '01 this weekend.
*Twin Cities MN*
Closed Thread
