Old 03-12-2003, 04:10 AM
ghostice ghostice is offline
95 engine into 91
Need help. I have 91 civic lx 4dr and i need whole engine, i have a 95dx civic engine, will the 95 fit directly in with no modification? will the mounts fit? thanks.
Old 03-12-2003, 07:39 AM
zippeay zippeay is offline
It would really help if we knew what kind of engine you want to put in it, is it Vtec? DOHC or SOHC? I think your car has a cable trans and the new engine you have is probably a hydrolic trans so you'll have to change that, its not hard you just need the lines and the resevoir. Other than that we need what kind of engine your putting in
Old 03-12-2003, 07:41 AM
OPPS I just read over you question again, it should drop in except for the clutch but I may be wrong about the clutch.
Old 03-12-2003, 07:58 AM
sorry about the missing info. its a sohc. non-vtec. i believe its the dx civic model, my engine is a 1.5 and it's 1.6. so besides that i do think the newer civic does have a hydralic clutch. no sure. thanks. let me know if you need more info
Old 03-12-2003, 10:48 AM
If its the 1.6 its not a DX, the 1.6 is the stock USD si engine, if you have that then your lucky cause it is Vtec. But I'm thinking that you have a 1.5 still, you must have if its a DX. The 1.5 should drop right in you just the the clutch master cylinder and the hose's for it and everything just plugs up, good luck
Old 03-12-2003, 03:30 PM
jamincivic's Avatar
jamincivic jamincivic is offline
It will drop in but you will have to use your 91 tranny.
JORDAN
My Si's Pics
Old 03-25-2003, 07:13 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Use your 91 tranny and the drivers side 91 motor mount and it will all bolt up and bolt in...still have to rewire for the ecu though...try www.thedropshop.tv for a wire harness adaptor....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
engine swap 85 engine into 88 truck spuds704 S-10 0 02-09-2010 10:33 AM
GTS engine into MRS etep_ MR2/MR-S 9 01-18-2005 06:13 PM
cobra engine into v6 engine bay? concept_Stang94 Mustang Talk 7 06-14-2004 12:45 PM
300M engine into 94 Intrepid Black94ES Engineering/ Technical 0 01-23-2002 03:18 PM
