Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 08-10-2008, 08:35 AM
cobraprince cobraprince is offline
Need Horsepower.
But does anyone know what my compression raito should be for a slant six to add a turbo charger or super charger?
Old 08-10-2008, 08:52 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Need Horsepower.
Its going to depend on a few hundred factors; cam choice, type of piston, what work done to the head, RPM range desired, EFI or carb? blow through or pull through? How much boost?
Way too many factors to just guess. The answer could be 6.5:1 or 9.5:1
We have a forced induction forum that might help better. I'm copying it over there.
Dragging people kicking and screaming into the enlightenment.
Old 08-10-2008, 10:50 PM
Ok, thank you for that. But I have a stock 1978, 225 slant six, with the super six pack. Does that help?
Old 08-11-2008, 10:19 AM
534BC 534BC is offline
Also what octane and type of fuel and driving/load would be helpful.
1978 stock ratio? (8:1)may be just fine for a mild street set-up with high octane pump gas.
Old 08-11-2008, 06:56 PM
I plan on running 92 octane or higher, and only driving on the weekends maybe slightly more and only the car and myself maybe a friend wich may total an additional 320 pounds as I only was about 145.
Is that better?
Old 08-11-2008, 08:08 PM
8:1 can probably run up to a 7-8 psi without cooling. 10-12 psi with cooling.
Old 08-12-2008, 12:29 PM
Thanks a lot. So does that mean I can run a turbo without an intercooler?
Old 08-12-2008, 01:15 PM
You can probably get away with a low boost system on 92 octane gas without an intercooler.
Old 08-13-2008, 05:01 PM
Awesome, so you guys should see some pictures and videos of a turbo charged hyper-pak volare some time within the next six months!
Old 12-11-2008, 01:58 AM
blackm20i blackm20i is offline
hows the project coming? any pictures yet?
Old 05-25-2009, 09:15 PM
Originally Posted by davidbravod View Post
HI,
can i see any picture of this upcoming
I've some pictures I've been meaning to put up. But we had an engine problem when I started it up about halfway through. So there was a major delay. I do however have a short video that hopefully I will get time to upload this weekend when I am off from work.
