Go Back   Automotive Forums Car Chat > Pontiac > Grand Prix > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here (for both Pontiac Grand Prix and Oldsmobile Intrigue)
Old 08-02-2008, 08:30 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Post Cooling System Bypass Elbows for SII 3800 Engines
When replacing the tensioner assembly or removing it to do a lower intake manifold (LIM) gasket job the two coolant elbows most likely will not remove intact so replacement will be necessary. Pics show broken elbows and new GM/Delco replacement elbows along with the latest GM part numbers.
GM/Delco Bypass Elbows
Top of pic - Elbow to lower intake manifold (LIM) - GM Part # 24503423
Bottom of pic - Elbow to water pump - GM Part # 12565082
Timeslip 08/12/06
AF Community Guidelines
Old 10-16-2012, 09:19 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Cooling System Bypass Elbows for SII 3800 Engines
New updated Dorman steel coolant elbows,
Dorman Part# 47065HP
http://www.dormanproducts.com/p-52351-47065hp.aspx
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-25-2012, 08:14 PM
FISH96 FISH96 is offline
aluminum not steel i believe
