Old 07-31-2008, 06:25 PM
ou812tj ou812tj is offline
88 Astro Van Question
I have a 88 astro van,automatic and it runs great until you put it in gear,then it quits.I have replaced the fuel filter,pcv valve, basically the easy things I know about.I've heard the toque converter can be stuck.I did jack up and it will run in gear off the ground.Any suggestions,Thanks Tony
Old 07-31-2008, 09:15 PM
old_master's Avatar
Advisor/Moderator
Re: 88 Astro Van Question
What is the 8th character in the Vehicle Identification Number, (VIN)? Have you checked fuel pressure?
Old 07-31-2008, 10:55 PM
Hi,Thanks for your responce,it's Z Thanks Tony
Old 08-01-2008, 10:09 AM
When I change the fuel filter on it and it didn't help,A guy who stopped to help out took fuel line apart at the filter and by the engine and said there was plenty of volume and preddure,but he had no gages or anything,just a coffee can,lol
Old 08-01-2008, 09:20 PM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
Had that happen in a '92 Lumina on the Jersey Turnpike - turned out to be the lockup (lockout? guy had a heck of an accent) solenoid in the tranny was bad.
Old 08-03-2008, 06:23 AM
Blue Bowtie's Avatar
Registered Offender
With the drive wheels elevated and running in gear, does the engine stall if the brake is applied?
