Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-10-2003, 08:32 PM
jmarvy jmarvy is offline
rust removal
I have a bad build up of rust i think came from worn out brake pads. This build up is all over painted aluminum rims can anyone suggest a way to remove it with minimum damage to surface
Old 03-12-2003, 06:43 PM
funkdaflex1 funkdaflex1 is offline
try spraying wd40 on the spot let it soak for a few minutes and try whiping it off if that doesnt work and u can repaint the wheel u can sand it. coke might even work to.
Old 03-13-2003, 02:22 PM
thanks funktheflex1 wd40 sounds like it may work dont know why i didnt think about that but will try it and let you know how it turns ou t thanks again
Old 03-19-2003, 10:35 PM
gnushit's Avatar
gnushit gnushit is offline
Send a message via AIM to gnushit Send a message via Yahoo to gnushit
wd40 on brake pad? won't that make your pads a little slippery?
go buy a wire brush attachment for your drill, and brush the rust away
"women are like guitars, they all come with strings attached" - king of the hill
Old 03-20-2003, 04:43 PM
thanks for your suggestion i didnt think of that if icould ever find the time i will try that and let you know how it works out
Rust Remover Wow s10blazerman4x4 Blazer 14 06-02-2006 05:29 PM
Rust removal? mrtwo Camry/Camry Hybrid/Vista 1 09-18-2005 08:32 PM
rust removal sb202 How-To's and Walk-Through's 2 03-15-2005 08:59 PM
rust removal... Fewman '88 - '91 Civic | CRX | Wagon | Shuttlee 3 06-12-2003 10:52 PM
