sorry for starting a new thread..
same car. has new issues. well sorta.. =) so.. the car stumbles and damn near dies as soon as you put it in gears drives horribly but revs fine in park or nuetral.. weve changed the transmission the egr, mass airflow censor, fuel filter, the code we are getting is still the same p0753 tranmission solinoid (cant spell sorry) the same code with both transmissions so im assuming the trans is not the problem we,ve checked the hoses for leaks found nothing i am so stuck right now.. and i have to work tommorrow!!!!!! lol so help is urgently needed.. thanx in advance!!!
Re: 99 grandprix stumbles under load.. (new issues)
Normally I would not allow a new thread on similar issues or ones that you have already addressed to the forum but I'll let it slide this time. However, just so we cut down on confusion and redundant answers here is the previous history at link below.
Click here
ok update...
just changed the ignition module and coil changed throttle posistion censor and still the same issue fine in park and nuetral when i shift down into park.. you dont see the effect right away until.... i take my foot off the brake the right back to the trouble.. i dont even have to gas it |
Suggest two things.
1. check the IAC motor (idle air bypass around the throttle blade), and more specifically the port which it meters...could be coked up due to PCV flows and not getting proper idle airflow, especially to compensate for the additional load of the torque converter working against a set of locked up clutch packs. The IAC should be able to compensate for the load in "D"rive before the throttle is cracked off the rest position. 2. check fuel pressure. Again you could be marginal enough on fuel pressure to run the engine against no-load...throttle "blips" don't use much fuel. But once into a load...again against the torque converter working against a locked up clutch pack that's ultimately restrained by the brakes. Could be a fuel pump itself. 3. Pinch off the vac line which leads to the vacuum brake booster...if there's any problem with the booster it could lead to a massive vacuum leak (unmetered air not compensated by fuel in order to maintain the desired A/F ratio). In general look for any other possibilites of vacuum leaks...a smaller possibility, as usually those would constitute an inability to idle in the first place.
1988 Chevy R-30 1 ton DRW pickup (217k) 1991 Chevy S-10 4WD pickup (192k) 2000 Grand Prix GTP (218k) 2002 GMC Yukon (185k) 2009 G8 - GT (46k) |
