Old 07-18-2008, 11:04 PM
phizzle phizzle is offline
99 grand prix stumbles under load PLEASE HELP!!=)
hey all .. i need your help here
i have a 99 grand prix
the engine runs fine in park..
but as soon as i put it in gear and take my foot off the brake.. it stumbles, backfires, and bogs..
the more gas i give it the worst it gets
so far weve changed the egr valve, disconnected the cat converter , and changed the #1 fuel injector (due to codes) all with no results
we are getting the code p0753
any help is greatly appreciated !!!!!!!!!!!
ive only got a a few days to get it running
Old 07-19-2008, 12:01 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 99 grand prix stumbles under load PLEASE HELP!!=)
I think P0753 has something to do with the transmission, but have you tried running it with the MAF sensor unplugged?
What motor and how many miles are on your car?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-19-2008, 02:46 PM
CrazyHorst CrazyHorst is offline
If it is not that, I think you have a fueling issue. Attach a gage to the schraeder valve on the fuel rail and see what you're getting.
A common failure amongst many GM vehicles, TBI to SFI included is the in-tank fuel pump in the 100-200k mile range. The TBI pumps seem to last a bit longer, guessing because they're under less stress since the output pressure is so much lower.
Old 07-20-2008, 07:33 AM
Carwhiz Carwhiz is offline
P0753 is a transmission shift solenoid code that can set under this condition: 1-2 shift solenoid has a wiring fault, which means you need to have your valvebody worked on. Not an uncommon repair on these transmissions, the procedure can be done without removing your transmission.
Old 07-20-2008, 02:28 PM
hey all thanx so much for all your hep!!!!
always appreciated for sure!!!!!
ok first question is.. the transmission repair..
we just put a new transmission in .. the junk yard gave us a bad one before
we had to take it out and replace it with a different one they gave to us..
they said they were sorry the trans was bad.. and heres a good one!! lol
so is that valve body job a big job?? expensive one.. and would that cause the engine to stumble and backfire and all that good stuff under a load?
i will check the fuel pressure also and with the maf sensor unplugged and i will get back to you as soon as possible
again thanx!!!!!!!!!!
