Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-10-2003, 03:26 PM
jimmyvoelker jimmyvoelker is offline
Send a message via AIM to jimmyvoelker Send a message via Yahoo to jimmyvoelker
Poping sound from rear end
Today when I was backing out of a driveway with my car in reverse of course and I put it into drive. Then I saw a car coming up behind me so I accelerated rather quickly and heard a loud popping sound coming from my rear end. Does anyone have any suggestions on what caused it? What should I do? Is this something to be concerned with? I have experienced this one other time when I did the same thing after backing out of a parking space. There isnt a huge jerking when this happens, just a loud noise and a slight jerk.
Thanks
Old 03-10-2003, 08:04 PM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
I've done so many ass jokes, I'll let this one go.
I'm really not sure what that could be unless you were in 4wd. If it can be reproduced maybe have the dealer take a shot at it.
I can only think of the LSD, or leaf springs/shocks (small chance). There really aren't many things that would do that back there.
Xterra4x4.com and the Xterra Offroad Webring
Old 03-10-2003, 08:22 PM
ChuckH's Avatar
ChuckH ChuckH is offline
Might check your driveshat U-joints. you can get under your truck and twist the shaft...if it's tight you're OK, if there is a lot of play your joints(s) are gone.
ChuckH
Old 03-10-2003, 11:23 PM
superjens's Avatar
superjens superjens is offline
Ass jokes are out, but this is acceptable?
superjens.com
I like saying aboot.
Old 03-11-2003, 02:58 PM
I looked at the driveshaft and it is tight and wont budge. I don't have an LSD so that couldnt be the problem. Also I'm sure I was two wheel drive so if anyone else has any ideas let me know
Jimmy
Old 03-11-2003, 05:19 PM
nflxterra nflxterra is offline
did you checked too see if you're parking brake was totally disengaged that could make the car "jerk" if it was partially engaged and also pop if you were trying to accelerate to fast with it on,
it could happen:smoker2:
Old 03-11-2003, 06:27 PM
Thanks for all the help, but Im sure that I didnt have the parking break on, because I had been driving for a half hour, pulled in the driveway, and noticed nobody was home, so i backed out and left again.
Jimmy
Old 03-11-2003, 08:03 PM
XTerra Guy
Well, you have a 2002 so you have to be under warranty, especially the powertrain one. I would just go to the dealer and have them do a once over.
Old 03-12-2003, 05:59 PM
yeah, take it to the dealer and let us know what they say about it. I don't have a clue?
Old 03-12-2003, 09:02 PM
XTerra Guy
The only other thing would be the leaf springs or their mounts. Is the spare tire tight against the body? I'm just trying to think of anything that could be loose and pop with a sudden change in direction
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 01:29 PM
2002 mountaineer 4.0 v6 RWD grinding sound from rear end jsoundguy Mountaineer 3 12-07-2006 01:50 AM
vacuum sound from rear end ohiocitylimit Crown Victoria 1 05-22-2005 01:14 AM
89 Suburban Has loud banging sound from rear end War_machine_No1 Suburban 2 04-12-2005 08:59 PM
