Old 07-13-2008, 06:58 PM
Funnyman141 Funnyman141 is offline
Question Would This work?
somebody said that if you have a hose leading from a high preasure area like the cowl and feed it into the airfilter it'll act like a turbocharger the faster you go the more boost you get is this true or false or have I finally found the cheap persons turbo? just wondering. oh and I'm new here so hello everybody!!
Old 07-13-2008, 07:27 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Would This work?
its called "ram air"
starts doing something useful around 120mph, but not much
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-13-2008, 09:36 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Its a trick that has been used for many years, but it doesn't provide boost like a supercharger. Someone did the math once and came up with something like .14 psi at 80 mph. That's good for about 0.1% more power
It should be viewed for what it really is; plenty of fresh cool air, which has its benefits, but the idea of ram air doesn't wash. The cowl, the top of the hood, and the grille are all places where "ram" air is sourced
Dragging people kicking and screaming into the enlightenment.
Old 07-13-2008, 10:28 PM
AF -Advisor
here's a fun little article involving motorcycle ram air, where they took pressure readings during a high speed run, and then attempted to reproduce the pressures on a dyno
Not very scientific, but gives a vague idea what results you would expect. Keep in mind, all the bikes they are testing have top speeds over 150mph, which most cars will never see
http://www.sportrider.com/tech/146_9912_ram/index.html
Old 07-14-2008, 11:56 AM
well how about a small air compressor added into the mix use the ram air for normal but when you need a bigger boost use the air compressor to force air into the motor or has it been done before? and is it a cheap turbocharger? and yes I may use these ideas on my car it has a small aircompressor in the engine compartment but the cable is to short so it's not much use and thats why I'm asking
Old 07-14-2008, 09:37 PM
vgames33 vgames33 is offline
I saw a video of someone hooking a leafblower to their civic si once. It was on youtube.
Old 07-14-2008, 10:05 PM
AF -Advisor
it would have to flow more CFM at a given PSI than the engine takes in to do anything. This requires quite a powerful compressor. Unless you're just using stored compressed air, which would be a very short burst
They do make electric superchargers, but they are extremely high amperage and can only be used for short bursts, even with multiple batteries in the car. Talking hundreds of amps
IMO, it is all very interesting, but when you are ready to get serious, pony up and get a turbo and stop messing around with these silly ideas
Old 07-14-2008, 10:40 PM
curtis73's Avatar
Its been done thousands of times before... its called a turbo
You can theoretically design an on-demand supercharger with EFI, but its pointless. A turbo is driven off exhaust gasses, so it only really provides boost when your foot is heavy. Its seamless and easy to do, but not cheap.
When considering adding forced induction, the only real way of doing it is by using a pulley (supercharger) or exhaust (turbo). Don't fall for any hype about electric turbos or compressors. Even my 40-gallon, 240 volt two stage air compressor in the shop only provides about 1/100th the volume an engine ingests. It takes about 4 minutes for it to develop 10 psi in the tank, so in an engine that ingests somewhere in the neighborhood of 1500 gallons of air every minute, you can see that it won't cut it in any way shape or form.
