Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-09-2003, 07:05 PM
JMS JMS is offline
Braking Problems
Sorry, Im new to these forums. I couldn't find a forum for brakes specifically.
Anyways: I just got a great deal on a '92 Buick Century w/ 52,000 miles, mint condition, for $900 (old people didn't have any room for it). Runs great, everything is fine except with the passenger side rear drum brake. Everytime I hit the brakes at a low speed it will lock up immediatly (no ABS), with almost no pressure at all. After driving awhile the problem will go away and it wont lock up at all. But then if I let the car sit for awhile it will do it again for about 5 mins until I wear the brakes a bit. It's very odd... Anyways I ended up replacing a cylinder because the old one was going bad, hoping that would fix the problem: But it didn't. So I bled the brakes, that didn't help either. I also swapped the drums (right side to left, left to right side).
Does anyone have any clue whatsoever to what might be casuing this problem? Im so clueless right now. It sat for 5 months out of the year so it is possible some of the parts are a little out of shape... Springs maybe?????
Please help, I don't want to wear my tire! :silly2:
Old 03-10-2003, 06:27 AM
Luke@tirerack Luke@tirerack is offline
replace the hardware and the shoes ... it sounds like you have either a weak spring or a contaminated lining
Luke Pavlick
Objects in the mirror appear ... to be losing !!!
Old 03-10-2003, 01:04 PM
JMS JMS is offline
Thanks, i'll look into that!
Old 04-02-2003, 04:43 PM
JMS JMS is offline
Nope replaced everything... any other ideas? Still locks up...
Old 04-03-2003, 08:45 AM
did the friction material get alot of brake fluid on it when the wheel cylider went bad ??? if yes re-place the shoes ... if no the star adjuster is probably to tight
Luke Pavlick
Old 04-03-2003, 05:15 PM
JMS JMS is offline
We cleaned the shoes, there shouldn't be an brake fluid on them. I still actually need to adjust the star adjuster, hopefully that will fix the problem. I'm going to do that this weekend, ill let you know if it works.
Thanks
89 ford bronco 2 brake problem bigd428 Bronco 0 09-13-2010 10:14 PM
brake problem, VERY hard brake pedal but VERY little braking power 95GMCJimmySLE Problem Diagnosis 23 10-24-2009 03:41 PM
Braking Problems frehleycomet Tracker 2 03-29-2009 11:46 AM
Brake Problem - Squishy peddle and brake light is on. ekingston Blazer 2 08-01-2004 10:01 PM
1991 Cougar brake problem. Brake Relay? psiege Cougar 1 01-20-2003 07:09 PM
