Old 07-05-2008, 06:25 PM
shaun005's Avatar
shaun005 shaun005 is offline
xsara picasso hdi tyres
First of all i would just like to say hello as i have just joined
I bought a xsara picasso hdi as the price of fuel is hitting the pocket as with us all,What i wanted to know is,there is 2 good tyres on the front 185/65/15 and as i got 2 good 195/65/15 would it be alright to put them on the back,
and would it be ok for the mot etc.any help would be appreciated
Old 07-05-2008, 06:56 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: xsara picasso hdi tyres
You'll pass an MOT fine so long as the tyres are the same size on the same axle. So 185/65R15s both on the back and 195/65R15s both on the front is fine. But you'll fail if you have a 195/65R15 and a 185/65R15 on the same axle.
On this car, you should have the same size tyres all round. If i remember correctly, these came with 185/65R15 Michelin Pilot Energys from the factory.
Seatbelts Saved My Life
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Should be fine since your car is FWD. The rear tires are just along for the ride. The 195s will be 10mm wider (5mm on each side) and about 3.25mm taller sidewalls - so 6.5mm larger diameter. Take a look and see if you have room. If you do, go for it.
Dragging people kicking and screaming into the enlightenment.
Old 07-05-2008, 11:36 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Just note that different tyre types and sizes front to rear will unbalance the cars handling.
My prelude has different brands front and rear, and I don't notice any difference 99% of the time, but pushed to the limit it is not as stable as it was when all 4 tyres were the same.
Old 07-06-2008, 05:32 AM
shaun005's Avatar
Thanks for the help lads i just had a look and i dont think i got the room for the 195/65/15 on the back i can just get my fingers in there on the sides,looks like ill have to buy a few the right size 185/65/15 well it was worth a try
