Old 03-09-2003, 09:32 AM
Snooker Snooker is offline
Why do I always need so much paint?
I work with Tamiya´s cans. I painted my Subaru Impreza with 2 cans, my VeilSide Silvia with 1,5 cans. Why? Today I sprayed the first layer on a Pick-Up and the can is nearly empty and I don´t understand why? The sprayed layer is covering everything, no primer could be seen.
Old 03-09-2003, 09:39 AM
freakray freakray is offline
AF Modelrater
You're applying waaay too much paint.
You're not meant to cover everything completely with the first coat, mist coats to start.....then when you have covered with 3 or 4 mist coats, wet coat.....
Read the FAQ
AF User Guidelines
Old 03-09-2003, 09:42 AM
Thanks. Hope that works.
Old 03-09-2003, 10:50 AM
rcmaxx rcmaxx is offline
I think you are putting many coats of heavy paint, when your just suppost to put lights coats then one maybe two heavy coats.
Old 03-10-2003, 04:05 PM
Jastor Jastor is offline
Can someone describe "mist coat"
I hear "mist coat" a lot, and I've even tried it on my Porsche, but I don't understand exactly what that means. Does it mean not spraying directly on the car, spraying from farther away, what?
I'd like to hear more on how to do mist coats.
Thanks!
--I am not a number, I am a free man!--
2001 VW New Beetle, 1983 VW Rabbit GTI
Currently Building: Fujimi Porsche 356
Old 03-10-2003, 04:08 PM
primera man's Avatar
"P-Man"
Re: Can someone describe "mist coat"
Thanks!
You spray quite away from the model so that the paint is only just landing on the model. You should be able to still "see though" the paint in places on the model after the first coat
View All My Models Here.
Old 03-10-2003, 04:40 PM
freelunch's Avatar
freelunch freelunch is offline
Mist coats dont seem to work very well when airbrushing acrylics. The wetcoats can't redissolve the rough surface of the mistcoats and causes bad orange peel.
Old 03-10-2003, 08:19 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
I always use 2 cans of paint. If I try to use 1, I can still do the paint job, but I buy 2 just to be sure I'm not gonna run out of paint like I sometimes do.
Old 03-11-2003, 05:23 AM
SirWelshy's Avatar
SirWelshy SirWelshy is offline
looks like i spray way to lightly then cuz i got 2 cars n a truck out of 1 can of Tamiya's
todo -->> Dan Finks speedwagon, taurus, lotus 107, `60 chevy hardtop, austin martin db6, austin healey 100-six, datsun 610? and bmw
http://www.pearce.50megs.com/model.htm
