| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
What to do with oil after you’ve changed it…?
Do you pour your used oil down the drain or throw it in the trash? I heard something about recycling the oil but I’m not really sure how that works.
If it exists, where could I recycle it?
By all means Recycle your used oil, never put it down the drain or in the trash. Most major auto parts stores will accept waste oil for free. I have a 5 gallon container where i put my spent oil, when it is full i take it to a local recycling center in my city where they take it for no charge. We all have to do our part to keep the environment clean. Al |
Re: What to do with oil after you’ve changed it…?
Just take it to Auto Zone, or Pep Boys or something. Sometimes even a generic repair shop will let you dump it in their barrell. They have services that come recycle it. Oil recycling is very common, not to mention the law. Chances are there are 10 places to recycle oil within 2 miles of your garage.
Dumping oil down your drain is just about as bad as dumping it straight into a lake or a stream. Its one of the worst things you can do environmentally.
Dragging people kicking and screaming into the enlightenment. |
In my state, (probably in others too if not Federal law,) any place that sells oil must take it back for recycling purposes.Like was said earlier, a good thing to do is get yourself a 5 gallon plastic container, like what frying oil comes in, and save it until it's full, then take it to the place that accepts it for recycling. Many restaurants that have fryers use oil in 5 gallon containers and are glad to get rid of them, so in most cases they are free for the asking.
I knew someone many years ago that dumped their used oil in a vacant lot in their neighborhood. When asked why he didn't recycle it, he exclaimed," I am. I'm pouring it back in the ground from where it came from. He actually thought thta was a good way to do it(!) (honest truth) :
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Around here (Iowa) most of the chain auto parts stores have a 20 quart per individual per month limit. That's one 5 gallon bucket per month, but I usually take it in about 12 quarts at a time.
-Rod |
In addition to auto parts stores, I have seen 10 minute oil change places accept your old oil........I personally would figure out a way to refine it or something and get it into your gas tank. Probably cheaper then $5 a gallon gas...lol.
I just change my oil while I am at work...
(No quart limit. lol)
Just do not mix your used engine oil with other old fluids. Throwing in old ATF or gear oil is okay, but brake fluid, anti freeze, and some solvents usually 'contaminate' the old oil making it virtually useless for oil recyclers.
Usually any place that accepts old oil will accept the other fluids too; just give it to them in a separate container. |
The council got big containers here in Cornwall for waste oil you just go and tip in in free,lots of builders used it with Wood cresote mixed for soaking and painting fencing posts before they were concreated into the ground,lots also used it for painting underneath their cars they tell me its good stuff for that
At work we have a big steel contailer, when it's full a truck comes and empties it.
Seatbelts Saved My Life
Any application on wood fence posts, rust proofing a car etc releases such contaminents into the environment. Do you really want that stuff in your own back yard? |
With the current price of crude, the oil companies should have to buy our used oil from us.
