Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 06-25-2008, 04:49 PM
AriasATX's Avatar
AriasATX AriasATX is offline
1992 Roadmaster engine troubles.
Hey there everyone, My fathers roadie has been giving him hell recently not wanting to run. He says the car starts and runs, But wont take throttle. And will die at idle after trying to give it throttle. The fuel pressure is 12psi.
He has replaced the Ignition module, Coil, EGR module(NOT VALVE), TPS, O2 sensor, And MAP sensor. And nothing. I was reading around the net and I think it is the FPR.... Anyone have any ideas? Thank's a bunch in advance.
Old 06-25-2008, 04:59 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 1992 Roadmaster engine troubles.
I think that the FPR is a good suggestion! Very common the older TBI motor. They are cheap and easy to replace!
Old 06-25-2008, 05:21 PM
AriasATX's Avatar
He is on his way to pick up one right now.
-Ben
Trying to keep our vehicles going one week at a time.
Old 06-25-2008, 05:52 PM
HotZ28's Avatar
AF Moderator Elite
Don’t get discouraged when you remove the old one and you see nothing wrong with it! They fail without any visible signs of failure! Strange, I know!
Old 06-25-2008, 06:08 PM
AriasATX's Avatar
That's is very good to know! Thanks.
-Ben
Old 06-25-2008, 07:27 PM
AriasATX's Avatar
Just got done putting in the new FPR and it did nothing. Anything else? I am thinking about just getting him to get rid of the money pit of a car.
-Ben
Old 06-25-2008, 08:13 PM
maxwedge maxwedge is offline
A990 racer
Lightbulb Re: 1992 Roadmaster engine troubles.
I may be wrong here but is not the 92 RM equipped with a 350 Chevy port injected engine which will not run on 12 psi, pointing to the fuel pump.
Old 06-25-2008, 09:23 PM
AriasATX's Avatar
It is a TBI 350, Not a TPI. The factory manual we have says 9-13psi and we have a little over 12.
-Ben
Old 06-25-2008, 10:48 PM
Blue Bowtie's Avatar
Registered Offender
Hmmm. I thought it was 11-13 on a TBI except for the 350s. I guess I was mistaken. I know the 350s had larger Maxi injectors.
Does fuel pressure maintain once the throttle is cracked? Are the injectors spraying a fine cone of atomized fuel, or just streaming/dribbling? It you keep the throttle closed but manually operate the lever on the TPS (pretty easy on a TBI), does the idle increase?
What is the base timing?
Old 06-27-2008, 01:45 PM
HotZ28's Avatar
AF Moderator Elite
In 1992 the Roadmaster got a 5.7-liter V8 engine that developed 180 horsepower & 300 ft lb TQ. It is the same motor as the 350 Chevy Truck motor (LB5) TBI used in the 88-93 models. It has a distributor, not an optispark. Have you change the distributor cap & rotor? How about the fuel filter?
Old 06-29-2008, 07:59 PM
AriasATX's Avatar
Have good fuel pressure, Put in a whole new dist today. We found it has intermittent spark on 1 and 2. What could it be? We think it has to do with the ESC.
-Ben
Old 06-29-2008, 08:21 PM
HotZ28's Avatar
AF Moderator Elite
Have you replaced the ingition wires? The ESC would affect all cylinders. BTW, you can have good fuel pressure without adequate flow. Have you changed the filter?
Old 06-29-2008, 08:47 PM
AriasATX's Avatar
We changed the 2 wires that were intermittent and it didn't change anything, The fuel filter is new aswell.
-Ben
Old 06-29-2008, 08:57 PM
AriasATX's Avatar
Also, Pressure maintains when you crack the throttle. The injectors are spraying a fine cone till you try and give it throttle then it sputters. And when you unplug the TPS the idle increases.
-Ben
Old 06-30-2008, 06:12 AM
HotZ28's Avatar
AF Moderator Elite
What is the voltage on the TPS blue wire with ignition switch on? Check the grey wire also.
