Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-20-2008, 01:00 PM
mlynn0096 mlynn0096 is offline
ac compressor
Is it possible to bypass the compressor on a 97 ssei can I buy a small belt and bypass the ac................thank you marsha
Old 06-20-2008, 01:30 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: ac compressor
Welcome to AF.
Yes you can but it is best to use a bypass pulley kit and use the original serpentine drive belt. See link below.
Click here
What is the issue with the A/C system?
Timeslip 08/12/06
AF Community Guidelines
Old 06-20-2008, 02:07 PM
Re: ac compressor
my compressor locked up. I turned it off the other day went in somewhere for 20 min came back out and my car was dead, all i got was clicking. My ac has been making noise for a while i think it finally went out..............thank you marsha
Old 06-20-2008, 02:13 PM
Re: ac compressor
Thanks for the reply. This is only a short term fix until I can get a compressor. Does anyone have a diagram on how the belt goes to bypass the ac..........thanks marsha
Old 06-20-2008, 07:59 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: ac compressor
It is the same routing as with the compressor!
Old 06-22-2008, 11:40 AM
Jrs3800 Jrs3800 is offline
Re: ac compressor
Do to the Motor mount, you will not be able to route the Belt to Bypass the Compressor... You will have to yank the compressor and install the Bypass kit...
Only other way is to get a new compressor..
Old 06-22-2008, 05:58 PM
Re: ac compressor
o.k. thank you for the reply. My husband tryed and said there is noway to do it so I ordered a compressor.............thank you marsha
