Old 06-18-2008, 12:45 AM
Highbeamz Highbeamz is offline
1.9 Rockers, Install
I am considering buying ZZP's 1.9 Rocker arms for my GTP (Series II S/C) amongst some other mods...
When installing the rocker arms, is there a specific way to torque them, and do you have to set them up a certain way...I haven't worked on a pushrod engine before, only OHC, and I don't remember doing too much valvetrain work.
Basically I want to take off the valve covers, change the rocker arms and have no valve train noise after I'm done (i.e only install once, not mess it up and do it again).
Any tips/advice?
Old 06-18-2008, 01:00 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1.9 Rockers, Install
Any link?
Are these the ER or real 1.9 ratio roller rockers? You follow the rocker arm torquing procedure based on the instructions provided by the manufacturer or supplier. The stock specs per the FSM adjustment procedure is normally not applicable.
On most 1.9 ratio roller rockers you have to be careful because you may have to upgrade to at least 105 lb springs or you will most likely get valve float above 6K rpms if you have a re-programmed PCM module. But the 105 lb springs may prematurely wear out a stock camshaft. To take full advantage the PCM module should be custom programmed to take full advantage of the new rockers and lift provided.
The procedure is relatively straight forward and classified as a DIY job. I have SLP 1.8 ratio roller rockers with the hp pushrods and the stock springs work fine.
Timeslip 08/12/06
AF Community Guidelines
Old 06-18-2008, 08:08 PM
Ok, I was looking at ZZP's rockers...which of course is down as I'm typing this...they're 1.9 rockers, basically old rockers with welded ends and remachined, they're 299 bucks.
Basically I was looking to lower the pulley size on my GTP, but I want a KR free ride and a couple extra ponies from the supporting mods. Basically the list was 3.4" Pulley, Headers (likely Pacesetter), U-bend delete if not included on headers, probably the rest of the exhaust system as well, FWI, and a v1.0 tuned PCM from ZZP.
From what I've read up that generally creates a KR free engine due to the extra air capacity (intake/exhaust) and I've read the stock fuel system can keep up to the demands of a 3.4 pulley.
I know how to install all these parts (they're all pretty straight forward) but I don't have any specifics, such as the rockers if they had a different procedure.
I want something to be overall reliable...you say the 1.9 rockers may cause more trouble than they're worth? I think the stockers are 1.6 right? So 1.8 would be better? Where did you get yours?
Old 06-19-2008, 08:48 AM
BNaylor's Avatar
Stock rockers are 1.6 which gives around .413/.408" on valve lift. The 1.8 takes lift to around .464/.459” which is ideal for reliable operation but a decent performance increase and helps keep KR in check. Also, keep in mind these are the aluminum roller rockers and not reworked stock. I got mine at 3800Performance. The complete kits depending on brand run around $400-$500.
Timeslip 08/12/06
Old 06-19-2008, 03:46 PM
Red Tipps Red Tipps is offline
Mind you also if you go 1.9 they will not work with an aftermarket cam due to the higher duration. So, if you want to do more modding in the future might want to keep that in mind.
Im planning on sometime in the future to get 1.9 rockers with ls6 springs . Im hoping to eventually be able to drop to a 3.25 pulley. Stock fuel injectors can handle down to a 3.2 I believe. As well as most aftermarket pcm's are only good for a 3.0" pulley I think...could be wrong there dont know the exact figure but its ballpark.
Also dont forget a cooler T-Stat and colder plugs with your 3.4. (Autolite 104's work well with the 3.4"), and a front O2 extension. Your headers will take care of your u-bend too
03' GTP Black on Black
S&S stainless headers
3" catless to resenator
JMB FWI
Intense PCM
Intense MPS 3.4/gatorback
AL 104's
180 tstat
Boost...have any?
Old 06-19-2008, 09:01 PM
The reason for my choice on the 1.9 rockers was the fact I'm not going to change the cam. But I do not want the car to be less reliable because I'm going to wear out the springs and/or camshaft. I'd much rather just change them and be done with it. Is there a general consensus on what's reliable?
As for the plugs and t-stat, I thought that was a given , then again I guess not everyone knows.
Old 06-23-2008, 03:47 PM
Didnt mean to insult your intelligence there, some people forget
JMB FWI
Intense PCM
AL 104's
180 tstat
Boost...have any?
