Quick Question: TT engine in an SL
Is it possible to put a VR4 engine in an SL without changing the engine mounts? I've heard that it is not.
I believe you can put it on without changing the mounts, but there is a lot more to turning a SL into a VR4/SL hybrid.
Resistance Is Futile (If < 1ohm) |
I was wondering the same thing. What all would this entail doing? And should I also use NOS?
"Never give in-never, never, never, in nothing great or small, large or petty, never give in to convictions of honour and good sense. Never yield to force; never yeild to the apparently overwhelming might of the enemy!" - Winston Churchill |
Thanks alot yogs. I think I'm just going to buy a VR4 instead of messing with the whole engine swap idea.
Just my opinion Phate, I would never use NOS. I think it's kind of pussy. I'd leave NOS for the civics. Plus, pumping explosive gas into your engine is never good for the car.
Yeah. It is pretty harsh on the engine I supose. I'll just work on adding the TT. Thanks Lick.
You wont regret the TT once you drive one
Yeah NOS will put some serious wear and tear on your engine. And, unfortunately, its not cheap to replace a VR4s block as opposed to the mouse on a treadmill civic ![]()
Hrmmm. . . I think my friend is on crack or something. Want to get your opinion. . . . He says that Single Turbo is better than TT. Thats not right. What do you all think?
A single vs multiple is a subjective choice. The VR4 uses a sequential turbo setting. The small one drives the big one so Turbo lag is quite short. A system that has two turbos (non sequential) will generally take longer to spool up then a single turbo of a larger size. Thats on of the reasons why you see a lot of supras converted over to a single turbo setup.
A single turbo setup can be considered better from an installation and maintenance standpoint. Its much easier to work with a single turbo setting then a dual one.
So what would each add to my already 220 hp?
Turbos add horsepower by the amount of air you move through them. For the stock 9b's that come with the VR4, you get about 10hp for every PSI you put through them. Because the VR4 are sequential, the 10 psi they normally put out gets us to the 320hp rating of the VR4. Most of us have boost controllers that can safely take it to 14psi which adds about 30-40hp.
If you were to just put a turbo on the car, you'd have to put in a decent gaugue and controller as well. If you were to go with a large 650DR you might be getting 15hp for every psi. Then you have to know how much boost your engine and turbos can handle. A lot of aftermarket turbo add ons can only safely run at 5-7psi (still a good amount of added horsepower).
Personally. . . . which would you install?
But if I had an SL and wanted to put one on, I'd look into a single turbo bolt on. It would be the least expensive way to go. I have not heard of anyone who has done that to it, but I would imagine that it could be done. Someone has had a low 15 second or a high 14 second run in his SL without using NOS so they can be made quicker without forced air. If you haven't stopped at www.3si.org yet, I suggest you do. The real 3000 tech heads hang out in there.Another kick ass site about these cars is http://www.stealth316.com/0-frames.htm take a look in the technical area for lots of info.
Thanks. I signed up for 3Si.org. Just waiting on the approval.
I'll see what I can do about the Turbo. For some odd reason my Insurance Co. swore up & down that it was TT. I had to take them out there and show them to prove it wasn't. lol. U would think they would know their cars better.
You might want to check and make sure they have the right VIN as your car. Thats how they tell the make and model.
