Old 06-03-2008, 07:04 AM
racer93's Avatar
racer93 racer93 is offline
Cutting side windows...
Here's a question I've never seen posted before and couldn't find with a search (maybe the wrong terms, but anyway...)--how does one cut out the side windows of a kit that has the windows all molded together? Would it be just like "opening" a door on a kit? Or, is there something more to it? I'm looking to do this on the Calsonic R34 Tamiya kit, fyi.
Thanks!
Daniel
Old 06-03-2008, 08:22 AM
stevenoble's Avatar
Re: Cutting side windows...
Do yo mean so you can represent the window in the open position? If so I have had success in the past using a very fine toothed razor saw (Zona brand) to cut the window and then fine files and sandpapers to clean up the edges of the cut.
Steve Noble
Old 06-03-2008, 09:50 AM
racer93's Avatar
Yep, that's exactly what i mean. Would scriber blades (like scale race cars') do the trick? I just wasn't sure since it looks like it would be more difficult to do than a door or hood...
Thanks!
Daniel
Old 06-03-2008, 09:56 AM
klutz_100's Avatar
photo etch saw blades are your best friend for this job but you can do it with almost any cutting tool I imagine if you are careful.
I have found that using Dymo labeling tape as a guide really helps in making a clean, straight job - it gives your cutter something to "lean" up against.
Old 06-03-2008, 11:37 AM
racer93's Avatar
Thanks, klutz! I appreciate it!
Old 06-03-2008, 12:30 PM
DerXL's Avatar
DerXL DerXL is offline
Just to add my 2 cents...
An SRC scriber will do just fine. Especially in combination with the Dymo tape tip from Klutz.
I've used an SRC scriber for parting the roof/front window part in a Tamiya XJ220 kit. Worked like a charm.
Good luck !
Axel
Visit my homepage for WIP's and galleries :
www.axelv.com
Old 06-03-2008, 05:33 PM
rsxse240 rsxse240 is offline
I just used the back of a new #11 blade when I cut out the glass on my J30/leopard. Had a bit more clean up to do than what that PE saw would have, I'm sure.
Old 06-04-2008, 03:53 AM
kaho's Avatar
kaho kaho is offline
I used dymo tape along with blade, no PE. It took me a few hours to cut out 8 windows off the fujimi EVO8 kit. Make sure not to make a single scratch outside of what you want to cut off because fixing scratches on clear parts are time consuming and it will always leave distortions.
Personally I don't think any tamiya kit requires such a mod. I only did it once because the window pillars on the fuijimi kit was close to 2mm thick - very visible even if you look at the model from a meter away.
