Ok, I Have A 1989 Chevy Caprice With A Fuel Injected 350. Well I Went To Start My Car And Once I Turn The Key To Crank My Car It Turned Over Slow. I Stopped. And Tried Again, Only This Time Everything Went Blank. No Power At All. I Looked Under The Hood And Moved The Positive Wire Around A Little And Power Came Back. Tried To Start Her Up And The Same Thing Happen Again. I Tried To Reconnect The Positive Wire(thinking It May Had A Bad Connection) But Once A Place The Positive Wire(wire From Starter To Battery)to The Terminal Their Was No Sparks Or Anything. Its Completely No Power. Earlier This Week My Battery Light Has Been Blinking As I Drive. I Checked My Spark Plug Wires And 1 Of Them Has Been Burnt A Little By My Engine. Can Someone Please Help. I Have Been Going Through Starting Issue's With My 89 Caprice For Almost A Year Now. It Seem Like Everything I Repair On Her Isnt Working. Please Help
Re: Please Help Me
Please See This Thread.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
Re: Please Help Me
Ok I read that. I'm sorry. I just really wanted to know what could I do. I have to be at work in the morning. My bad. Could you help me out please !!!!
Re: Please Help Me
Sounds like there's either a) internal post damage on the battery - new battery time (this happens more often than you would like to believe with side post terminal batteries), or b) a loose or corroded cable. It could be loose at the starter, as well as internal corrosion in the terminal. New cable time if that's the case.
Re: Please Help Me
Ok. Thanks. So the burnt spark wire plug want hurt anything?
Re: Please Help Me
Re: Please Help Me
Ok thanks
