Old 05-24-2008, 02:53 PM
b16crx91 b16crx91 is offline
1997 GTP wont rev past 3500
I have a 97 GTP that starts and if i dont give it gas it dies and if i do give it gas it sounds like it hits the rev limiter at 3500. Ive checked the fuel filter and its good I put a pressure gauge on the rail and it loses pressure. Ive also done the bypass on the fuel pump relay and the car idled good but still popped out at 3500. does anyone have any idea????????????? I think its the fuel pump but dont wanna spend that much money if its not. can some one please help??????
Old 05-24-2008, 06:13 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 1997 GTP wont rev past 3500
Pull the vacuum line off the fuel pressure regulator. Then turn the key to ON but not start. Get any fuel spraying out?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-26-2008, 01:59 PM
no fuel coming out of the regulator
Old 05-26-2008, 04:28 PM
doctorhrdware doctorhrdware is offline
Could it be a cat converter that is partially clog.
Old 05-26-2008, 09:49 PM
no i dont think so cuz i put a pressure gauge on the rail and the fuel pressure does drop
Old 05-26-2008, 10:03 PM
inafogg inafogg is offline
i thought there was a limiter not allowing u to rev over 3.5k
Old 05-26-2008, 10:15 PM
Yes there is a limiter, but it would be higher than 3.5 K, more like 8.5 k. I belive that if you do not use overdrive, and using 3rd gear the RPM's would be higher.
If the pressure is dropping at the rail, that sounds like the fuel pump. When is the last time that the fuel filter has been replaced.
Old 05-26-2008, 10:32 PM
well thats just it i checked the filter and ive also checked the relays and the fuses. I did the resistor bypass to put the pump in high speed mode and it idled but it still would not rev past 3500
Old 05-27-2008, 06:42 AM
hercman hercman is offline
If the tranny is in park the rev limiter kicks in at 3500.
Old 05-27-2008, 08:34 PM
tblake's Avatar
In God We Trust
I'm assuming the reason its idling with the resistor bypassed is because of the higher fuel pressure.
You need to find the leak, which can be complicated without a full fuel pressure tester set.
Would hate to tell you its the pump for sure and you throw a 300 bucks at a pump and its not your problem.
You did look for external leaks around the fuel filter, right? (didnt you say you just changed it?)
After that there are only two places fuel can go, into the combustion chamber due to a Leaky injector, or back into the tank due to a failing pump.
Ohm out all the injectors and see if there are any ones that dont match the rest. This might point to a leaking injector.
Pump replacement or fuel pressure regulator replacement is up to you, would be the next step...
Old 05-29-2008, 02:16 PM
ok i pulled the vaccum line off the regulator and turn the car on several times then when i hooked the vaccum line back up the car ran perfect for two days nows its acting up again. pressure regulator?
