Old 03-05-2003, 07:51 AM
Geez Geez is offline
Future, Priming, Painting, Tamiya masking tape
OK, so I've expanded my modelling capabilities by buying some Future and Tamiya masking tape. Now, I wanted to try this stuff out before I botched up a good model, so I took an old kit I had built, that had been molded in colour, and I hadn't sprayed. It was also a decal intensive kit. Applied the Future, and it looked pretty good. Let that dry for a week, and tried the masking tape. Well, the tape promptly pulled all the Future off with it. It also pulled the decals off. Now, this is semi acceptable, I suppose, considering there was no paint layer.
Here's the question. If I paint Tamiya TS paints on a plastic body without roughing or priming the body, will this happen again?
If I rough and primer the body, and spray Tamiya TS paints, could this happen again?
Recently completed:
Tamiya Mobil 1 NSX
On the go full time:
Tamiya Porsche 911 GT1
On the shelf to start:
Jagermeister 155 Alfa Romeo
Ferrari F40
Old 03-05-2003, 07:53 AM
k_dog's Avatar
k_dog k_dog is offline
Send a message via ICQ to k_dog Send a message via AIM to k_dog Send a message via MSN to k_dog Send a message via Yahoo to k_dog
I would imagine this would'nt happen if you primer the surface.
Old 03-05-2003, 12:53 PM
daggerlee's Avatar
Did you wash the plastic body before applying the decals? One theory is that the mold release agents, which are basically just slippery chemicals, prevented the decals and future from having a good ahesion.
From my experience, Tamiya tape is one of the best tapes for modeling, period: low tack, bleeds very little, see-through when applied correctly. I don't think you'd have a problem with a good primer and paint on it.
Dan
Old 03-05-2003, 04:39 PM
freelunch's Avatar
freelunch freelunch is offline
Future is delicate. If your not careful polishing the stuff, whole pieces will flake off.
Old 03-05-2003, 06:47 PM
JDM Evo7 JDM Evo7 is offline
Future is not a good clear coat, it's too fragile, it's used mostly in military models. On those you use future to apply the decals, then overspray with a flat coat. I like Tamiya clear. It dries very hard, easy to polish, etc. It is a lacquer so you just have to put on several light coats to seal the decals, before you apply the heavy coat.
Old 03-05-2003, 06:54 PM
djmr2's Avatar
djmr2 djmr2 is offline
Future is Acrylic based, it dries very thin so if your going to use it as a clear coat, be prepared to spray lots of coats. Sometimes when u think you've over done it, you'll be surprised how thin it is when it's dried out.
I've used it and i had absolutely NO problems polishing. Great Shine.
Old 03-05-2003, 07:07 PM
freelunch's Avatar
djmr do you wetsand future? I wetsanded and the future redissolved even after a week of drying
Old 03-05-2003, 07:38 PM
djmr2's Avatar
i usually do wet sand, so i'm pretty sure i might have wet sanded the future. you probably didn't put enough future on..
i did that once and when i reached the color coat it looked like the future was disolving.
try putting atleast 10+ coats on.. meaning u want to spray it on a little thick cuz it dries really thin.
Old 03-05-2003, 07:45 PM
Mainomega Mainomega is offline
Future really is trick and not worth the effort i think. My paint jobs on two current models are awesome, today i sprayed future on them and now as always orange peel develops.
I've spray this stuff a lot and i always stick with it even though i tell myself not to use it anymore.
If you let the future dry atleast 3 weeks it is perfectly good for polishing and sanding. Spraying Future isn't the same as spraying paint. I tend to do very thin coats and build up. The shell ends up very shiny and "hard" but i always develop orange peel. I guess im a cheap bastard because a bottle of future cost $6 and a small tamiya clear costs $2 so i stick with Future everytime.
Got Something Good ? E-mail me
Old 03-05-2003, 09:10 PM
djmr2's Avatar
Future is basically paint...
don't blame future.. your probably just doing something wrong
orange peel is so easy to get rid of and yet everyone makes a big deal with it... use some sandpaper and smooth it out, then take some polish and voila, u have a shiny model without orange peel
Future is cheap.. thats an attractive thing for an expensive hobby.
Old 03-05-2003, 09:12 PM
freelunch's Avatar
After i wetsanded, the future began to get white and cloudy. Has this happened to anyone else?
Old 03-05-2003, 09:13 PM
djmr2's Avatar
you probably got down to the paint layer and ur seeing the transition from future to paint...
tahts my guess
Old 03-05-2003, 11:19 PM
freelunch's Avatar
Hmm, I left the model after and got cloudy and went back to it a few hours later. The future had apparently dried again and the cloudiness was gone. weird
Old 03-06-2003, 12:22 AM
ales's Avatar
ales ales is offline
Forza Schumacher
There was a thread not so long ago, and the consensus was that sanding future is both not necessary and not recommended.
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
