Old 05-08-2008, 11:24 AM
Didymus Didymus is offline
Flat Finishes Are Too Shiny
I'm having trouble getting a truly flat finish. I've been using Tamiya TS flat black, but it comes out sort of satiny. I've tried overcoating it with Model Masters Lusterless (flat) Lacquer Overcoat and Floquil Flat Finish (probably the same stuff), but I still get a semi-gloss.
I've heard that it's important to shake the heck out of the spray can because the flattening stuff is on the bottom, so I've done that too. It hasn't helped. I've actually thought about using 800 grade sandpaper, but it would be hard to get a uniformly flat finish, and the scratches would be sort of directional. Plus there's the burn-through problem, especially if there are edges involved.
I read somewhere that Pactra makes a clear that's really dull. I've searched the web, but haven't found it.
Any suggestions?
Ddms
Old 05-08-2008, 11:30 AM
Joe Blyth's Avatar
Joe Blyth Joe Blyth is offline
Re: Flat Finishes Are Too Shiny
I like Polly Scale clear flat. It's nearly perfect for me.
Old 05-08-2008, 12:47 PM
slk320 slk320 is offline
AF Premium User
Send a message via AIM to slk320
Use testors flat black - perfect flat chalky color
In Progress:
FXX - test mule in CF
49' Mercury
Old 05-08-2008, 01:38 PM
Martin S's Avatar
Martin S Martin S is offline
I have had success with spraying from a really long distance. (haven't tried it with tamiya, but with automotive flat black spray paints)
This way the paint mist starts to dry in the air and the paint will not flow out when it lands on the model. The surface will have a rough, but uniform texture.
Try to experiment with spraying distance and you will get the hang of it.
Latest progress:
Ferrari F40 LM Fujimi 1/16 and Porsche 959 Fujimi 1/16
Finished:
1940 Ford pickup and Lotus Super Twelve
Old 05-08-2008, 02:00 PM
ZoomZoomMX-5's Avatar
Testors flat black lacquer is much more a true flat black than Tamiya.
My Fotki Album
Old 05-08-2008, 07:23 PM
bizzychris's Avatar
bizzychris bizzychris is offline
Use testors flat black. And make sure you're not spraying too closely.
Old 05-09-2008, 01:16 AM
sjelic's Avatar
sjelic sjelic is offline
exactly, and not to much, light coats will make effect you want.
Sasa Jelic
SCALEMAKERS
Old 05-09-2008, 11:19 AM
rsxse240 rsxse240 is offline
I was just about to suggest using thinner coats. I had the same problem. I solved it with Krylon ultra flat. you will find NO flatter black in the world. It looks like evil when it's dry. like you just sprayed a black hole on your model. it actually sucks light out of the room it is so flat and black. oh, and when it's dry (about 10 minutes after it's sprayed) it's got a rather durable finish. suprisingly difficult to marr up like most flats.
Old 05-09-2008, 12:17 PM
Sounds like there are some better flat blacks around than the Tamiya I've been using. I'll give Testors and the Krylon a try. And I'll spray from a longer distance!
Polly Scale sounds like a possibility for a flat clear, but it comes in a bottle, doesn't it? I was hoping to find a super-flat clear in a spray can.
Ddms
